P1870
Old May 4, 2016 | 06:16 PM
600 horses's Avatar
Default P1870
99 Silverado, 5.3, 3.73 gears, performabuilt 4l60e lsx trans. About 2 weeks ago my truck increased line pressure and was hitting so hard between shifts it would bark the tires on the 2-3 shift. I shut it off and let the pressure drop then a week later it kicked the p1870 code for trans slippage. I have researched and everything I have read says I need to change my valve body and TCC selonoid. Does anyone know about this issue. I know sonnax has a rebuild kit but need to make sure it's what I need. Thanks for the help in advance.
Old May 4, 2016 | 09:35 PM
Wolftrk99's Avatar
If you have a built trans i would suggest talking to thrm about it first, but typically yes its a valve body issue, gm even has a bulletin on it fir harsh 1-2 shift and p1870 stored in history... Torque converter could be an issue as well!!
Old Jun 24, 2016 | 02:31 PM
600 horses's Avatar
So I have talk with Performabuilt. They removed the PWM function in the valve body. Now I have changed the fluid and filter and everything looked good. I still have good shifts but the converter isn't locking up the way it was. Are there any suggestions on testing the converter or do I take the hit and bye another converter? Any suggestions are appreciated.
Old Jun 24, 2016 | 02:50 PM
Wolftrk99's Avatar
Where did the converter come from, should be under warranty...
Old Jun 25, 2016 | 11:21 AM
terravast4's Avatar
i had this issue with my performabuilt. i lost my overdrive and drove it that way for a long while then it started to get hung up shifting from 1st to 2nd. I ended up buying a FLT level 7
Old Jun 25, 2016 | 05:18 PM
600 horses's Avatar
The trans is out of warranty but the converter was shipped with it.
Old Jun 25, 2016 | 06:01 PM
Wolftrk99's Avatar
Well in that case if the converter came with the trans they are probably both out of warranty then....
johnnymart610
Aug 26, 2017 02:31 AM
Wolftrk99
Jul 29, 2016 01:07 AM
HDhotrod
18
Mar 18, 2016 10:49 PM
Chevy6.Zero
Mar 11, 2016 08:43 AM
Txyote
Feb 20, 2016 02:41 PM
