Official A4 to M6 (T-56) Thread!
Old Jan 5, 2007 | 04:34 AM
  #111
04GIBBS's Avatar
Ah damn not McDonalds??
My friend today is at his machine shop making a new Rod bent to work and sit in its proper location.
So far my problem with the pedal being low was due to a bad Master Cylinder that leaked. Now is the fun game of bleeding the system.
Old Jan 6, 2007 | 12:31 AM
  #112
nice_n_lo_silverado's Avatar
Ok ordered the pedal and other things 1truess has. does anyone have the part number for the shifter itself and the lines, hoses, and stuff like that?
Old Jan 6, 2007 | 06:25 PM
  #113
Mater's Avatar
Originally Posted by Quik
when we did my buddys car. the ram clutch came with a shim for the slave. and in the instructions along with on tech you need to drill the part that is on the braided line. you drill about 1/2" then you hit another way another 1/2" in. so when your finally dont its a total of one inch of drill bit going in the line
we
Old Jan 8, 2007 | 12:03 AM
  #114
eviltwin_1987's Avatar
I have a t56 and bellhousing from a lt1 camaro. What would it take to put that behind a ls motor? By the way 6 speed trucks are bad ***.
Old Jan 8, 2007 | 12:42 AM
  #115
TurboGibbs's Avatar
A different input shaft (4th gear) and a different bellhousing for sure. There may be more differences?
Old Jan 8, 2007 | 12:47 AM
  #116
What shifter are you guys using? standard 5speed truck or ls1 Camaro or what?
Old Jan 8, 2007 | 03:06 AM
  #117
TurboGibbs's Avatar
F-body. Get an aftermarket short throw shifter because of the longer handle you have to makes the throw pretty long without it and if you do it with a console the throw may be to long to clear the opening. I have a SLP shifter.
Old Jan 8, 2007 | 03:36 AM
  #118
MustangPunk's Avatar
Wish I could put a t-case behind a t-56...
Old Jan 8, 2007 | 11:13 AM
  #119
UnrthdxDream's Avatar
word.... i have seen it done on a syclone on here.... but man i dont know how i would match the tcase to the t56 like he did...
Old Jan 8, 2007 | 06:32 PM
  #120
negativeswitches's Avatar
i saw a site somewhere (forgot where) that someone Made a tailshaft to bolt to a t-case they wanted like 500$ for it but it would be awsome
-erik
