Official 14 Bolt 9.5 SF Truck Thread
Old Aug 15, 2015 | 10:45 AM
  #31
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by gao8302
Has anyone used a 14 bolt out of a Chevy express van? Will the factory disc brakes fit on this with the obvious modifications? I'm going with a custom set of bogarts anyways so wheel figment isn't an issue.
GM 14 BOLT REAR END WITH 3:73 GEARS AND 9.5'' RING GEARS. THIS WAS OUT OF A FULL SIZE CHEVY EXPRESS VAN 2000-2002.
OUTSIDE TO OUTSIDE OF SPRING PERCH IS ABOUT 53 1/2''
INSIDE TO INSIDE OF BACKING PLATE IS ABOUT 58 1/4''
George
From what I remember they are offset to 1 side and They are also wider than the standard GMT800 rear ends. I am not sure the leaf spring width is the same either.
Old Aug 15, 2015 | 12:16 PM
  #32
gao8302's Avatar
From what I can tell the axle looks centered. It also appears that the axle is roughly 3" shorter from backing plate to backing plate. Hmmm?
Old Aug 25, 2015 | 08:35 PM
  #33
signguy62's Avatar
Aside from needing to swap 8 lug to 6 lug axles, will a 2000 Yukon 9.5/14bolt w/discs swap right into a 2000 Silverado?
Old Aug 25, 2015 | 09:14 PM
  #34
1FastBrick's Avatar
A NBS Yukon XL 2500 housing will fit and you can swap the 8 lug axles to OBS 6 lug axles but there is only 1 solution that I am aware of for the brakes.
Thats to make a new brake mounting flange and weld it to the housing.
The 2500 and 1500HD 8 lug brakes have a different offset from the 1500 6 lug counterpart.
Old Jun 10, 2016 | 09:40 PM
  #35
jmk121's Avatar
Smile
Anyone have a part number for the axle shaft for the AXN for a 2006 Sierra. G80, GT5, JF3, possibly a less expensive replacement than the OEM part? have seal leakage with groove in axle shaft and the repair bearing wont let the clip fit back in place.
Thanks
Old Jun 11, 2016 | 11:54 AM
  #36
1FastBrick's Avatar
Thanks
Call Dutchmen. I sent them an axle from a 2006 AXN and had them make me 2 sets.
They have the dimensions and can make you a pair of axles that is better than factory for 1/2 the price of just 1 axle from GM.
Last time I checked GM wanted around 550ish for just 1 axle.
Old Jun 11, 2016 | 09:34 PM
  #37
jmk121's Avatar
Thanks, I will give them a call Monday. Do you know the GM part number? I have been searching the diagrams and the one that appears to be the hybrid axle does not have a part number or description for the axle shaft.
Thanks again!!
Old Jun 17, 2016 | 10:50 AM
  #38
axisT6's Avatar
UPDATE! A guy on the performance trucks face book page posted this info for converting the NBS 8 lug 14 SF to 6 lug:
Yukon Axles - YGA-21425
03 Express 2500 6 lug Van Brake Rotors
Apparently the 6 lug van rotors will work with the existing parking brake, caliper, and caliper bracket.
Old Jun 18, 2016 | 02:22 PM
  #39
1FastBrick's Avatar
Same fitment? not offset to one side?
Did he post any pictures? I am not on FaceBook
Old Jun 28, 2016 | 12:21 PM
  #40
axisT6's Avatar
Facebook is evil. What do you mean by offset? There was a pic, however the post is buried now.
