NVG149 Transfer Case On GMT900 Sierra Denali
Old Feb 20, 2008 | 05:42 PM
Bostonsfavson's Avatar
Default NVG149 Transfer Case On GMT900 Sierra Denali
I did a search, but it didn't come up with the info I was looking for. Here's the situation: I have a 2007 GMC Sierra Denali AWD with the L92/6L80E. It's a great truck to be sure, but I'm less than thrilled with the performance of the AWD system in the snow. I've had a few trucks with the NVG149 transfer case, and I think it's one of the best cases ever made; it's certainly better than whatever they put in the GMT900 trucks. My question is this: does anyone know if the NVG149 can be installed on this truck? Unfortunately I'm not sure what kind of case is in there now, and therefore don't know if the shafts will line up or anything of that nature. Any advice/info/input is greatly appreciated. Thanks guys.
Old Feb 20, 2008 | 08:16 PM
04Denali's Avatar
when I changed to the 4L80 I had to put in a different input gear for the 80
Mark
Old Feb 20, 2008 | 09:38 PM
I could handle that. Nice to see you here Mark. Hope that everything is going well with the transmission.
Old Feb 21, 2008 | 03:19 PM
Wide Open's Avatar
Only problem I can see other than having to change the input shaft is the NVG149 transfer case is expecting a shaft speed reading from the sensore while the AWD unit in the 07 doesn't have any such inputs/outputs.
I agree the new AWD case sucks for anything other than pavement.
Old Feb 21, 2008 | 03:41 PM
KevinF56's Avatar
what does the new t-case do differently than the old ones to make it crappy in the snow?
Old Feb 21, 2008 | 03:47 PM
Wide Open's Avatar
IT SUCKS!
Seriously though, it seems the system is heavily rear biased (I assume the rear brakes activate to transfer more power to the front wheels because there is no electrical connection to the transfer case).
Old Feb 21, 2008 | 05:00 PM
Bish's Avatar
Thought this might help. Looks like it is 38% to fronts and 62% rear split. I thought the Denalis DID use the NV149!
For the record, I LOVE mine. In the snow, I have found AWD works better with Traction Control disabled.
NVG 149 Transfer Case Description and Operation
The RPO NP3 is a single speed, single mode transfer case. The mode is full-time all wheel drive. It has a planetary differential gear set that splits the torque, normally 38 percent to the front wheels and 62 percent to the rear wheels.
The NVG 149 utilizes magnesium housings. Proper fasteners, brackets, and fill/drain plugs must be used to prevent galvanic corrosion. The planetary differential uses the carrier (6) as the input. The annulus gear (4) connects to the rear output shaft (5) and rear wheels. The sun gear (3) connects to the front output shaft (7) and front wheels through the chain (8) and sprockets. The viscous coupling (2) consists of a sealed housing filled with a high viscosity silicone fluid and thin steel plates alternately splined to the inner and outer drum. The inner drum is connected to the input shaft (1), and the outer drum to the sun gear (3). Whenever there is a speed difference between the front and rear wheels, the inner and outer plates of the viscous coupling spin relative to each other and the silicone fluid provides resistance. The resistance was tuned to be high enough to bias power quickly to the wheels with traction, and low enough to prevent binding in a tight turn on dry surfaces. This is the most common way the viscous coupling is activated, the shear mode. If the speed difference is high, the coupling can lock or hump. This "hump" occurs when the heat generated, expands the fluid inside the housing, changing the fluid dynamics between the plates. This results in pressure between the plates, forcing them into contact with each other, similar to a clutch pack. In the hump mode, the coupling can bias torque 100 percent to one axle, if required. Situations requiring this are extreme such as backing up a steep gravel grade or climbing over off-road obstacles. The viscous coupling is not serviceable; it must be replaced if defective. This is because each viscous coupling is calibrated for optimum vehicle performance for both the shear and hump modes. If the viscous coupling is in the "hump" mode too long, severe damage will occur. To prevent damage to the viscous coupling, DO NOT:
Tow with only two wheels down
Drive without one propshaft
Drive with a "donut" spare tire for an extended period of time
Power Flow - No Wheels Slip
During normal operation, 100 percent torque is delivered to the input shaft (1) from the transmission. The torque is split to 62 percent to the rear output shaft (2) and 38 percent to the front output shaft (3), by the planetary differential. Because there is not a loss in traction or slip in the front or rear wheels, the viscous coupling is locked in place and there is no "shear" mode or "hump" mode involved.
Power Flow - Front Wheels Slip
When traction is lost at the front wheels, the viscous coupling works in conjunction with the differential to bias the torque more to the rear wheels. The rear torque goes higher than the 62 percent, and up to 100 percent torque to the rear output shaft (2). The torque at the front output shaft (3) is lowered from the 38 percent, to as low as 0 percent torque.
Power Flow - Rear Wheels Slip
When traction is lost at the rear wheels, the torque is biased to the front wheels. The torque to the front output shaft (3) goes higher from the 38 percent, up to 100 percent torque. The torque at the rear output shaft (2) is lowered from the 62 percent, to as low as 0 percent torque.
Customers may have concern that the transfer case is not operating properly because one set of tires spun for a brief period. It is normal for one set of tires to spin until the viscous coupling engages.
Turning off the traction control switch, if equipped, enhances the function of the viscous coupling. The viscous coupling, as described above, engages by heat. Allowing one set of tires to spin or slip for a brief period will generate heat in the viscous coupling. The engine speed should be kept at a constant speed during the brief spin of the tires. Pulsating the engine speed or hard acceleration will not allow the viscous coupling to operate properly.
Go http://www.denalitrucks.com/documents.htm for a link to the doc with pictures.
Old Feb 21, 2008 | 08:14 PM
They used to, but not on the GMT900s. I'm not impressed with this new system at all. It just plows through turns when it's snowing out; the understeer is terrible. That's why I was hoping I could rig up the NVG149.
Old Feb 21, 2008 | 08:18 PM
04Denali's Avatar
Talk to Butch over on denalitrucks.com
I am sure he could help you figure it out.
Mark
Old Feb 21, 2008 | 08:35 PM
He's not sure either Mark.
