NP246: 99-02 vs. 03-07
Old Jan 5, 2018 | 09:22 PM
  #21
LSrBEST's Avatar
Yea no doubt. I’ve got a 99 NP246 I’m hoping to stuff into my suburban with the 80e swap as it came with the trans but the suburban is a 2004! Dam! Good thing is the t case was free. Looks like I’ll have to figure out the actuator issues out the old fashioned way. Trial and error or I suppose I could take the input shaft from the 4l80e t case and swap that into my current t case which is matted to a 60e with no second gear. I guess I didn’t think about that. Anyone here know if that’s the way to go? Take the input shaft from the ‘99 246 and swap into the ‘04 246? As the newer 246 was built for the 60e and I’m swapping the 60e with an 80e. just like the rest of us I’m trying to minimize downtime and hoping for some insight before I get dirty. The truck in my sig is parked for the winter so I’m down to 1 set of wheels.
Old Jan 5, 2018 | 09:33 PM
  #22
Ford_Assassin's Avatar
Come Get Some!!
If you have both the 99 to 02 and 03 to 07 cases, have a shop swap the shaft for the encoder and it's a done deal. The input shaft from the 4L60e will not work on a 4L80E or vice versa. Spline counts are different, 27 vs 32, if memory serves.
Old Apr 1, 2018 | 12:42 AM
  #23
Mike1987's Avatar
Registered User
Default Transfer case swap
I have a 2003 1500 hd with a 246 t case i bought one dude said it was attached to a 4l80e but i found out it wasnt can i change input shafts from mine and the encoder shaft because they will be different as well or ahoild i just find the right case thanks
Old Apr 3, 2018 | 11:47 PM
  #24
megabuddys's Avatar
The input can be changed out easily by a skilled Driveline guy.
https://cobratransmission.com/np-246...SABEgIyPPD_BwE
Old Feb 16, 2020 | 12:29 PM
  #25
franktank25's Avatar
Registered User
Originally Posted by joeyc125
Anybody know what the differences are between the 99-02 and 03-07 autotraks? I will be buying a reman case for my 2000, was wondering if a newer version will work. I know the newer ones don't have the front shaft spinning all the time, and will shift out of 4wd under full throttle. Anybody know?
The splines are different coming out of the transmission. 27 to 32.
Old Feb 16, 2020 | 01:46 PM
  #26
arthursc2's Avatar
thats only true when changing transmissions
4L60: 27 spline (all)
4L80: 32 spline (all)
year of case does not dictate spline count. The transmission it was behind is the dictator
nickpc82
Nov 2, 2015 02:49 PM
Chavette
Oct 28, 2015 07:33 PM
silver-mod-o
Oct 23, 2015 02:05 PM
bgray
Sep 16, 2015 07:33 PM
black00chev
16
Sep 15, 2015 05:40 AM
