Not so Ugly Hitch
The hitch that came on my truck is ugly, it hangs down too far, and the trailer light bracket was welded on crooked.
I modified the hitch by notching the round tube and raising the receiver to the bottom of the bumper.
Then I put the trailer plug behind the license plate.
I saved the hitch rating sticker and put it back on, now I'm waiting for a spring loaded license plate hinge.
Thanks for compliments.
I trust my welding skills. I have been doing it for a while.
It does not look to good in this picture
But I worked on it for several more hours before I was done. I'm no engineer but I think it's stronger than the factory unit.
I took the factory hitch apart (with a big grinder, and sawsall) in less than 1 hour. It will take several hours to take apart the one I welded.
But you would laugh at my equipment.
An old buzz box, the on off switch is broken, and the **** to change the amperage is broke off. I use vise grips to change the amps, and I wind up the welding leads on the pipes for the gas meter.(once was a man his name was Jed)
I melted about 15 1/8 inch rods into this thing, it will hold.
