noob question on stall
Old Jun 8, 2006 | 02:15 AM
TouchOfEvil04's Avatar
Originally Posted by Soon2bSpooled
your rpms on the highway will increase about 2-300 though. this is due to the the fact that with the stall there is less rpm drop between shifts. i once cruised 65 @ 1800 now at 2000 and 70 @2300
Wait do what?I have a stall dude...my rpm are no higher than before....Once the converter locks its as if a stock verter was in there and thats how yours should be as well.
The less rpm drop is only when you shift it drops 300 less than the stocker basically if you dropped to 3000 before when you upshift you should only drop to 3300...But this has no effect on locked performance.If yours is making you have higher rpms while the verter is locked then something is wrong with that converter.
Old Jun 8, 2006 | 03:06 AM
maybe im mistaken i dunno. the converter is fine i know that much i was just letting him know his rpms will drop less between shifts. mine locks up fine and maybe i just never paid attention to it before the verter.
Old Jun 8, 2006 | 03:17 AM
Cuerva's Avatar
11 Second Truck Club
Originally Posted by Gmc1999
i know i know, try seraching and i did first couldnt find it, question being is how a 3000 stall acts under normal driving condtions, like if im goin say 20 and i accelerate normaly will the truck not move at all untill 3000 or will it still move close tho it did at stock but when you hammer it it jumps to 3000
It depends on how loose the converter is. At 20mph a 3k converter will be sliping till it locks up. If you hammer it it will flash up to 3k or more and start pulling and will lock at a higher mph.
Old Jun 8, 2006 | 03:20 AM
Prob. so cause if it locks up fine then you should pull the same rpms you did before.My before 70mph 1942-1955.
After verter 70 mph still 1942-1955.
Old Jun 8, 2006 | 03:30 AM
under light acceleration in city driving you will probably be between 2000 and 2500 rpms the whole time. it will hurt your mileage but it will probably be one of the best mods you can do. under the stock tune (no verter corrections) you willl lock up about 45-55 mph under light-mild acceleration. if you stomp on it, with just a 3k you probably wouldnt notice any lock-up speed because you would be higher than 3000rpm until you let off the throttle
Old Jun 8, 2006 | 06:54 AM
RabidStreetRacer's Avatar
Originally Posted by trever1t
Yes.
Depending on whos stall from what i gather. I have a Yank TT3000. When i roll on the throttle i will move, but the converter is slipping. When throttled up good the rpms go right to 3000. It's fine around town but real fun on the highway!
Why do you say it's real fun on the highway?
Old Jun 8, 2006 | 08:12 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Because the shift extensions are shorter...when i go from 1-2nd for example, my rpms gp from 6600 to 4200+ dumping me in second and pulling hard.
Old Jun 8, 2006 | 10:10 AM
thats a big drop IMO. when i shift i 6200 i get dropped to 4500...what stall and cam do you have? seems like you shouldnt drop tht far
Old Jun 8, 2006 | 10:14 AM
trever1t's Avatar
Dude!! You have a 3200 stall? Yeah, your shift extensions will be different!
Old Jun 9, 2006 | 12:23 AM
whats your stall at??
