no TCC after shiftkit install.
Got it all done has all forward gears and reverse perfectly. Where should I look I'm thinking the converter ISO valve assembly. Everything went together perfect and the truck only has a notch over 20K miles on it. It is setting trans slip code and it will not lock using my tech 2 and commanding it to 100%. Does anything else done during the shiftkit install effect converter oiling circuits. I also used new gm valvebody and spacer plate gaskets. It's a transgo hd-2. in an 07 old body style sierra.
Is the iso-converter valve in the right way? Should have the threaded end toward the outside of the valve body and the blue spring should be installed first. Could you have damaged one of the TCC solenoids when you removed them? I would pull the pan and check for anything obvious, and double check everything you did. Also with the Tech 2, turn the key on with the engine off, and command each solenoid on and off and you should be able to hear them clicking.
This is the first thing I would look at from what you describe. You will get no lock up with the Transgo converter regulator valve installed backwards.
GMCtrk
38
08-09-2015 08:50 PM
