New Ridetech Rear Wishbone setup for 99-06 Trucks
Old Feb 28, 2018 | 02:30 PM
Reckless's Avatar
Still moddin'
Default New Ridetech Rear Wishbone setup for 99-06 Trucks
Just got this in email from my guy at Ridetech. Nice option:
File Type: pdf
Old Feb 28, 2018 | 03:07 PM
ILuvJDM's Avatar
Interesting... And I assume it keeps factory gas tank. I wonder if you have to use their notch, or if a Mcgaughys notch would work
Old Feb 28, 2018 | 03:52 PM
arthursc2's Avatar
Looks like you have to use theirs, the mounts are built into the frame rails they supply.
Old Mar 2, 2018 | 09:39 AM
BigKID's Avatar
Glad to see they are still developing stuff for the GMT800. I presume the system will be for a predetermined height as I do not see any adjustment in the bracketry. I know ridetech's focus is on handling and keeping the control devices closer to wheel helps with this. However, being a leaf spring replacement outside the frame does very little for adding wider wheels/tires. I am curious to see this system installed and put thru it's paces for a review on the handling/ride improvements over leaf springs or even their existing four link.
Old Mar 2, 2018 | 11:04 AM
Reckless's Avatar
Still moddin'
Kind of what I told John at Ridetech. His truck was the test mule. He said they tried moving the shocks inside the rails and the dynamics were all wrong. I asked how much tire it would take with this set up and he has not replied yet. I am thinking 315s at best. I was hoping for 345s
Guess I might just back half the thing We'll see
Old Mar 6, 2018 | 03:12 AM
Mconcha's Avatar
Any kit ride tech makes can have an altered ride height if you change shock mounts OR coilover size, spring height, spring rate, valving..
It all depends on why you’re purchasing their kit.
Fitting wide wheels to go fast in a straight line was not their objective.
Old Mar 6, 2018 | 02:32 PM
Reckless's Avatar
Still moddin'
You are correct. I mostly want the wide wheels for appearance. I rarely drag race. But I would be nice to use all that space up to the frame rail.
Old Mar 7, 2018 | 01:09 PM
BigKID's Avatar
You have to consider the wheel wells are also a limiting factor. To put a tire all the way to the frame would require mini-tubbing the wheel wells too.
Old Mar 7, 2018 | 02:47 PM
Reckless's Avatar
Still moddin'
Already bought those Just need to install them.
Old Mar 7, 2018 | 10:44 PM
Mconcha's Avatar
Haha comin prepared! post progress on the build! Can’t wait to see it all in action!
