new gears are here: question on install?
Old Aug 30, 2006 | 10:04 PM
gmtechnician's Avatar
Default new gears are here: question on install?
the 3.73s that i ordered came in today. i plan on having a dyno tune done but its going to be a couple of weeks before i can get tuned. i want to put in the gears now. so my question is will this hurt anything. does anyone else have different gears with no tune. or should i just wait?
Old Aug 30, 2006 | 10:08 PM
sroach20's Avatar
i did 3.73s before my tune and it ran perfectly fine.
Old Aug 30, 2006 | 10:11 PM
will i see any lights like the ABS or something?
Old Aug 30, 2006 | 10:18 PM
sroach20's Avatar
i didnt see anything. i put the eaton and 3.73s at the same time.
Old Aug 30, 2006 | 11:08 PM
vanillagorilla's Avatar
I had my ABS light and parking brake light go off about 1 mile down the road after doing my gear swap. Your front wheel speed sensors will be reading different from what the PCM thinks the VSS is doing.
Old Aug 31, 2006 | 06:15 AM
adam1803's Avatar
you may get an abs light, but it wont hurt anything at all. Just remember that your speedo will be slightly off, it will read higher than you are actually traveling.
Old Aug 31, 2006 | 07:04 AM
dewmanshu's Avatar
Moderately Differentiated
with 205/75/16 & 3.23's your speed in 3rd gear @ 2000rpm will be about 50mph.
with 205/75/16 & 3.73's your speed in 3rd gear @ 2000rpm will be about 43mph.
So, in theory, your shift points and TCC lockup speeds will be about 7 mph off. Not a big deal. You may notice a gear hanging a little longer or shorter and the tcc not applyng when it used to until you get that gear # changed to help the speedo/vss reporting. You may not notice a difference due to the a wide shift selection in your settings. Obviously your speedo will be off. Everybody above is right, ABS light, speedo, and shifts. No harm no foul, get it changed though.
Old Aug 31, 2006 | 07:35 AM
virgils4.85spd's Avatar
Default Youll prolly get a
abs and parking brake light. I drove mine for about a month. I went from 3.42 to 4.10 and my speedo was way off but it wont hurt anything..
Derek
Old Aug 31, 2006 | 07:55 AM
sroach20's Avatar
am i the only one that didnt have the lights come on?
Old Aug 31, 2006 | 08:23 PM
yup
The message you have entered is too short. Please lengthen your message to at least 5 characters.
