Need some help - Can I replace converter with Tcase & Tbar member in place?
Old Mar 30, 2008 | 10:58 AM
Moddoo's Avatar
Arrow Need some help - Can I replace converter with Tcase & Tbar member in place?
I have searched a lot. Still unsure.
I am in the middle of my HD2 install.
Truck is on the ground.
Before I put everything back together, I would like to do my converter swap.
I only have 1 decent floor jack.
I don't really want to pull the Tcase or Trans out of the truck. Or pull the Tbars.
Can I slide everything back and down enough to do the swap?
Alone?
I can do it on a lift next weekend. But, I would rather not do the whole Y-pipe thing again. Plus I have very limited free time.
Thanks in advance.
Old Mar 30, 2008 | 01:43 PM
James B.'s Avatar
If you have limited time then don't try a converter swap - especially on a 4WD truck.
The exhaust has to come down because the engine needs to tilt back for access to all the bolts on the bellhousing. Both drive shafts have to come out.
It is possible to support and move the transfer case rearward once unbolted from the transmission. I have done it with the harness still attached. It will go far enough to drop the transmission out from in between. The transmission has to come down, trying to swap a converter without taking it down is dangerous. Converters are heavy and have a major effect on the transmission's center of gravity.
If you're doing this in your garage or driveway, plan on having your truck up on four drive-up ramps and spending an entire day for JUST the converter.
Old Mar 30, 2008 | 02:19 PM
Moddoo's Avatar
Thanks James,
I guess I will wait till next weekend.
First time playing with an auto.
I keep triple checking everything, and definately won't have enogh time today.
Old Mar 31, 2008 | 01:06 AM
joeyc125's Avatar
11 Second Truck Club
If ya want i can come up and give you a hand, ive got an extra jack and some stands too. Converter is next on my list also...
Old Mar 31, 2008 | 01:25 AM
kbracing96's Avatar
FYI, it IS possible to swap the converter without spiting the transfer case from the tranny or dropping the t-bar member. I did it on my truck. It will slide back far enough and the front will drop down enough to do it. It's not easy, but possible.
Old Mar 31, 2008 | 08:38 AM
Moddoo's Avatar
Thanks guys.
I spent most of the day on the shift kit and cleaning up.
Wish I would have done it long ago. Works great.
Joe, I have a friend helping me with it in his shop next Sat.
Thanks for the offer. Hit me up if you want to come by and see how it goes.
LCHEE
Oct 24, 2020 04:10 PM
Oobray
Aug 12, 2015 10:56 AM
carid
Aug 2, 2015 08:45 PM
76k10chase
Jul 17, 2015 01:48 PM
