Need new rear end ASAP, Need Info!
Old Jul 7, 2005 | 11:58 AM
Jewmont3's Avatar
Default Need new rear end ASAP, Need Info!
Blew the rear end. Need a new one. It can be rebuilt but probably not worth it. Especially with the engine swap down the road. Can anyone suggest what I can replace my rear end with that wont kill the bank? 12 bolt/14 bolt and even maybe a ford 9 inch that doesnt need much custom fabrication and from what trucks and years? thanks,
Mike
Old Jul 7, 2005 | 01:34 PM
black4x4's Avatar
find a 6 lug sf 14 bolt and it should bolt right into your truck the 12 bolt would be like your 10 bolt and i bet the 9in would take some work to get one under there.
Old Jul 8, 2005 | 12:05 PM
Jewmont3's Avatar
what about a 14 bolt FF will that bolt up? I think those are all 8 lug tho but not sure. What kinds of power will these things handle? I am planning a heads/cam LS1 swap in the near future and some other mods. Probably be close to 500ftlbs or torque. Can these 14 bolts handle that?
thanks,
Mike
Old Jul 8, 2005 | 02:24 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yup they are all 8 bolt but I thin k someone has a 6 lug conversioon for it.
Old Jul 8, 2005 | 02:26 PM
StrokerAce03's Avatar
I think the full float 14's are 8-lugs as well. 2500's used to come with a 6-lug 14-bolt called the "metric" 14-bolt i think. Its strong enough to handle the power.
Old Jul 8, 2005 | 06:39 PM
Jewmont3's Avatar
If I can find a 14 bolt Full Floating I am pretty sure I can get custom 6 lug axel shafts cheap enough. The other worry is I hear these things are heavy as hell and there are ground clearence problems. While I am not trying to make my truck a race car I do still want the thing to move after all the money I dump into it. It is stock z71 height right now but Im planning on lowering it just a few inches but that depends on the rubbing of the tires. I do occasionally tow with it on dirt roads and crap as well. I just dont wanna get myself into trouble here. What do you guys think? I read someone say this thing weighs like 500lbs over a 10 bolt or something crazy like that. Is that true?
thanks,
Mike
Old Jul 9, 2005 | 02:53 PM
Jewmont3's Avatar
Ttt Ttt
Old Jul 9, 2005 | 11:58 PM
litreddevil's Avatar
Banned
What Mods Do You Have To Keep Breaking The Rear End.a Friend Of Mine Has A 14 Bolt That Comes Off A Hd I Think Like I Said I Think It Has 4.10 In It.
Old Jul 10, 2005 | 01:18 AM
black4x4's Avatar
a 14 bolt ff wieghs in at around 450 to 500 with disks. to have one made to 6 lug rebuilt and geared and locked you would probly have around 2000 in it.
Old Jul 10, 2005 | 01:44 AM
Jewmont3's Avatar
Hmmm, I only have full exhaust and intake on my 95 TBI 5.7L and I broke it doing a 3 second burn out. Must have already been really weak that should have never happend. But since it blew and I am planning on big power numbers in the near future with an engine swap I want to do this once and right the first time. Will a 14 bolt SF hold up to my expected 500ftlbs or torque in the future? Also how much weight savings with that over the FF. What can you guys tell me about the Dana 60 rear end?
thanks,
Mike
pjb1972
Sep 17, 2015 02:06 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
