Need a new converter
Old May 18, 2007 | 03:34 PM
thunderwagen's Avatar
Default Need a new converter
Well I guess I need to step up to a bigger converter. I have a 2800 stall in it right now. I went to the track last night and tried to brake boost the truck to launch under boost. As soon as it would start to build boost mabey 1 - 1.5# it would start pushing the truck. My 60' times were horable and it didnt really start to build boost until the 60' So time for a new converter.
Im thinking somewhere around 3200, but am open for suggestions. Also im trying to decide between Yank and P.I. give me your opinions and experiences.
Mike
Old May 19, 2007 | 05:32 AM
You could always upgrade your brakes, that might help. What cam do you have?
Old May 19, 2007 | 07:30 AM
.T.'s Avatar
.T.
I'm going with a PI cuz of the hardened shell and multi-disc. The truck is so heavy, it's worth spending an extra few hundred$ and never worry about it. Plus, 2 year warranty and a free re-stall if you're not satisfied.
You might wanna call over to PI and talk to Jack about it. Sounds like a 3200 Vig will put you where you want to be.
.02
Old May 19, 2007 | 08:23 AM
ranwalk's Avatar
Your converter may be fine. You need to load the engine to build boost, not really rpm's with a turbo, right? Not positive since i'm not running a turbo. Anyway, you may want to think about losing the 4.10 gears. Some 3.73's or 3.42's would most likely help you load the engine more and build more boost at the line.
Old May 21, 2007 | 02:56 AM
Cam is stock.
I do think the drum brakes that the truck came with hurt while trying to brake boost it, but I dont really want to do a disk conversion right now.
The turbo thing is new for me too, and I am wanting to get some input from guys who are running them.
Old May 21, 2007 | 06:13 AM
FLT's Avatar
FLT
FormerVendor
Call precision and tell them what you have. They do make some special internals for turbo applications to allow you to make some boost off the line. I think this might help you out. I believe they call it a turbo stator. Good luck, Vince.
Old May 21, 2007 | 12:57 PM
thanks Vince
jscherbs
Mar 24, 2017 07:20 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
TAPyvehc93
Jan 8, 2016 10:47 AM
jtphelps289
Sep 11, 2015 06:37 PM
06 4.8
Sep 11, 2015 10:36 AM
