Need a little more drop
Old Jan 11, 2007 | 11:58 AM
dirtyratt's Avatar
Default Need a little more drop
2004 stepside by the way. I have the DJM 2/4 drop but I want abought a 1 inch more drop in the back what have you guys done to get alittle more drop out of the back...Thanks
Old Jan 11, 2007 | 12:31 PM
KevinF56's Avatar
well you could do spring clamps to get a little more drop, but i hear that gives a kind of rough ride. also it doesn't drop it too much. it might be what you're looking for.
unfortunately if you need more than that, you might have to do a flip kit giving you 6 inches of drop, then put a 1 inch lift shackle netting you 5 inches of total drop.
or you could always throw **** in the bed.
Old Jan 11, 2007 | 01:57 PM
02BlueStepside's Avatar
Either do the flip kit and 1" lifting shackle, or get a set of hotchkis 4" drop leafs, put your stock hangers on, and set the shackle at 1".
Old Jan 11, 2007 | 02:46 PM
KevinF56's Avatar
oh good idea. i should have thought of that.
either way though you're looking at spending more money.
Old Jan 11, 2007 | 02:54 PM
97Redbirde's Avatar
Dude take out your rear overload spring. It took me about 30min. just take the U-Bolts out and remove the center pin and take it out and put it all back together. You get about and inch and it drives the same.
Old Jan 11, 2007 | 05:19 PM
dirtyratt's Avatar
or you could always throw **** in the bed. [/QUOTE]
LOL ,Thanks your FUNNY I needed that though
Old Jan 11, 2007 | 05:21 PM
dirtyratt's Avatar
I might try that. Thanks for you help guys
Old Jan 11, 2007 | 11:25 PM
StrokerAce03's Avatar
I took the overload out of my spring pack as well. It did give about 1" of drop but the axle wrap was so bad I ended up putting them back in and installed spring clamps. Doesn't give as much drop but doesn't have the problem with axle wrap. I agree with 02bluestepside about the flip kit and lifting shackles though; seems to be the best way to go IMO.
Old Jan 12, 2007 | 07:54 AM
KevinF56's Avatar
if you do the flip kit with lift shackle you're most likley going to have to notch the frame if you haven't already.
Old Jan 12, 2007 | 09:01 AM
97Redbirde's Avatar
Can I ask what you mean by axle wrap?
