Need help -- vibration // Gas and a match if I can't figure it out
Old Jul 31, 2011 | 12:17 AM
stevenc's Avatar
Default Need help -- vibration // Gas and a match if I can't figure it out
I have a 02 ECSB with a 2 inch drop shackle (no hanger). Its been on there for about 2 years now, no vibrations no nothing. Recently my carrier bearing started making alot of noise.
So we replaced the Ujoints and the carrier bearing.
And there comes the vibration -- 40mph it starts and cleans up around 80mph. Worse on the freeway.
I never shimmed because I never had a vibration.
What we have done so far:
Used both 2 and 4 degree shims, with the fat end pointing both directions.
Moved the carrier bearing bracket backwards and forwards.
Used a completely different drive shaft off my friends truck.
What else could it be? It did not present until we replaced the carrier. My old one had a TON of slop for about 70k miles. Never had a single bit of vibration.
Do I need a carrier relocation shim with just a shackle drop?
Is my frame bent?
Do I light it on fire?
Thanks.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
MA$TER_E
Sep 9, 2015 03:14 PM
jleews6
Sep 8, 2015 10:17 AM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
