Need help with these spindles ASAP
Old Nov 16, 2012 | 12:15 AM
RickyMartinZ28's Avatar
If/When you disassemble it, the shaft will be set in the hole and won't spin when you unbolt it. I'm not sure what the problem would be.
Old Nov 16, 2012 | 05:32 AM
Zeke2007's Avatar
Originally Posted by 2000chevysilverado
Usually I replace the ball joints for good measure since its apart and new ones dont spin while tighting them. I will be doin my 2/4 this spring and get me a pass throughsocket set
Little tip the new ball joint studs spin to.
The ball joint stud spins no matter what thats y u have to use a allen key.
But ur screwed once u cut the stud off.
Old Nov 17, 2012 | 10:00 PM
Johnmaster's Avatar
MASS seller approved
when you take the nut off it won't spin, it will need to be popped with a ball joint separator to get it to come loose.
Pimpinpete
43
Dec 22, 2017 08:13 AM
GM1697
Sep 28, 2015 08:28 PM
MOBBN
Sep 22, 2015 08:07 PM
