Need help with these spindles ASAP
Old Nov 15, 2012 | 02:11 PM
Zeke2007's Avatar
Default Need help with these spindles ASAP
I cant figure out how to tighten the top ball joint bolt all the way. I kno u have to use a allen key but my problem is how are u sopose to get the bolt completely tight when it is counter sunk into the spindle?
You cant use a socket bc u have to use an allen key to hold the stud from turning.
Once th bolt is sunk into the spindle u cant use a wrench..
Need a little help here
Thanks
Old Nov 15, 2012 | 02:44 PM
2000chevysilverado's Avatar
Do you have the pass through socket set. Mainly used for allthread in construction work you couod still put a allen wrench on the stud
Old Nov 15, 2012 | 02:48 PM
Zeke2007's Avatar
no i dont is that the only way??
Old Nov 15, 2012 | 02:54 PM
Thats what I can think of at the moment did ya do a google search
Old Nov 15, 2012 | 02:56 PM
Zeke2007's Avatar
ya nuthin came up but where to buy the spindles lol
Old Nov 15, 2012 | 05:32 PM
livefast1's Avatar
pry down on the control arm with a big *** prybar to put tension on the taper while tightening it up.
Old Nov 15, 2012 | 05:44 PM
Zeke2007's Avatar
i got it thanks guys
i went and bought a pass through socket set thanks again
Old Nov 15, 2012 | 05:54 PM
Camaro Zach's Avatar
That is one of my major dislikes of Mcgaughy's spindles
Old Nov 15, 2012 | 06:00 PM
Zeke2007's Avatar
Ya tell me about it. I dont get why the damn ball joint stud spins. Then u gotta cut the stud off bc its too long. Makes me wonder how the hell ill ever get it back off?? Bc once u cut the stud off u cant use the Allen key anymore. I gess ill have to torch it off if it ever comes to it
Old Nov 15, 2012 | 06:44 PM
Usually I replace the ball joints for good measure since its apart and new ones dont spin while tighting them. I will be doin my 2/4 this spring and get me a pass throughsocket set
