Need Help Quik With Belltech Drop Shackle!!!
Old Sep 25, 2005 | 06:10 PM
TravisH's Avatar
Default Need Help Quik With Belltech Drop Shackle!!!
I got the shackles installed but I need to know which way the shims go for adjusting the pinion angle??? thick side to the back or to the front???
Old Sep 25, 2005 | 06:28 PM
02BlueStepside's Avatar
I have some in mine, but I currently can't get under it to see which way they are. I am 99.9% sure its thick side to the back because when you give it gas the nose of the rear end will twist upward so you want it to point down when stopped. I don't think you need shims for just a shackle drop though.
Old Sep 25, 2005 | 10:33 PM
Keith's Avatar
By doing a shackle drop, you are raising the rear of the springs and angling the axle downwards.
I'd think that the fat side should go towards the front to angle the axle back up.
Old Sep 26, 2005 | 12:15 AM
TravisH's Avatar
i just decided to put the thick side to the back, that angle the front on the axle up. got it all in tho and it lowered it exactly 2". I am very pleased with the drop, and it looks awesome. I will try to get pics up tomorrow.
Old Sep 26, 2005 | 07:43 PM
WhiteChevy3's Avatar
i just put some on mine , thick side facing the front
Old Sep 26, 2005 | 11:36 PM
TravisH's Avatar
ok I think ill switch it tomorrow
Old Sep 27, 2005 | 05:48 AM
02Reaper's Avatar
thick side goes to the front
Old Sep 27, 2005 | 02:12 PM
i had to think about it for a while too....
Old Sep 27, 2005 | 03:23 PM
Just for reference, I did a search and came up with this...
http://www.djmsuspension.com/Product...inionShims.htm
Basically it says, if your axle is below the leafs, then the thick side goes foward. If the axle is above the leafs, then the thick side goes back.
FlyingLow
Nov 24, 2015 10:05 AM
BCraven1018
Nov 2, 2015 07:18 AM
jpweb90
Sep 17, 2015 06:32 PM
dhorner77
Sep 11, 2015 05:10 PM
Dezmo
Sep 9, 2015 02:09 AM
