need help identifying a LSD
Old Apr 13, 2011 | 11:22 PM
chevyrace47's Avatar
Default need help identifying a LSD
so i picked up a different 14 bolt, this time from a 4x4. i scored big time with this one. it has 4.10s and some form of lsd or something like that. anybody know what it is?
Old Apr 13, 2011 | 11:25 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Gov-Loc. AKA G-80. AKA timebomb. They often end up looking like this.
Old Apr 13, 2011 | 11:30 PM
Looking closer at your pics, specifically the 2nd one, the side & spider gears look a little galled. I'd consider building the axle before installing it.
Old Apr 13, 2011 | 11:32 PM
hmm, thats not cool. are the 14 bolts that bad also?
Old Apr 13, 2011 | 11:35 PM
also not cool
In my opinion, it depends on the driver and what you're doing with the truck. But if your side & spider gears are galling, it's already junk.
Old Apr 13, 2011 | 11:37 PM
what makes them do that?
Old Apr 13, 2011 | 11:42 PM
One wheel peel, abuse basically. I'd bet the clutches are also worn out.
If you wanna re-use the gear set, Check the pattern and measure the backlash before teardown. Then set it up exactly the same when you go back together.
Old Apr 14, 2011 | 10:32 AM
so if i want to keep this, what should i replace?
Old Apr 14, 2011 | 10:50 AM
Gadgetized's Avatar
You can't rebuild those.
