need help
Old Jun 13, 2007 | 03:47 PM
  #21
onebadrubi's Avatar
Originally Posted by RandomHero
Dude there's a pretty big difference between a 2 door coupe camaro with 26" tires and a 5000 lbs silverado. You're going to have a TON more drivetrain loss with a silverado than a camaro.
Not to mention that a cam that big is going to make it's power WAYY into 6k rpms. Who wants to daily drive a truck like that? It would blow.
400 is an obtainable number on motor. The 5.7 guys are making it a little easier on a stock rear end and stock blocks becuase of rotational mass, very little actual drivetrain difference. Their cranks are lighter. That motor is just a little better on the dyno. Not to many trucks are dyno queens, heck we have a 330hp truck on here runnin 12.4.
A good cam selection, high compression, some "massaged" heads, through a 4l60e and you will be thier. 4l80e is going to suck a little more power.
DLH2006 hit like 381 or 391 with a 224/224. You dont need a HUGE cam like the trex, actually that cam is to big for a DD IMO. The torquer 2 or something along the lines of a 230/233 in that area is capable of making 400hp. It aint all about the cam, that just helps a little bit.
Good cam selection
compression
heads
intake.
Those will net you over 400.
Old Jun 13, 2007 | 04:07 PM
  #22
Tootall's Avatar
Originally Posted by onebadrubi
. . Their cranks are lighter. . . .
5.3 5.7 and 6.0 have the same cranks. I've never heard anything about them being lighter.
