NBS V6/V8 rearend differences?
Did the NBS V6 trucks get the same 8.5 as the 1500 v8 trucks?
Can’t seem to find the info I was searching for.
I have the opportunity to pickup a v6 rearend from an 04 Sierra from a buddy for very cheap.
My truck is primarily a tow vehicle, it’s a 99 Silverado 1500 with 3.42 gears.
I’ve noticed my buddies 05 Sierra that has 3.73 gears, tows a lot better and gets way better mileage than mine.
Both 5.3 trucks.
I’m debating doing a gear swap to 3.73’s while I’m doing the truetrac.
I thought the likely hood of the v6 rearend being an open diff was pretty great and it would be better to do a truetrac and gear swap on that rearend instead of tearing apart my good working rearend that’s in my truck now.
I can’t seem to find any solid info on what gears the v6 trucks got, but I’m betting it’s not anything I would want.
Both 5.3 trucks.
It should be the same axle but the year will dictate drum or disk brakes. Not sure if they gave the V6 trucks 4.10s or not but my 4.8 truck had 4.10 gears which would be even better than the 3.73s for towing.
makes children cry
yeah, "towing" & "3.42s" don't usually end up in the same sentence unless it's talking about ditching the gears.
the v6s & v8s had the same rear ends in most 1/2 tons (with a few exceptions like the 1500HD, SS, etc). open or G80 locker was luck of the draw among them (4x4 often had a locker but not always), and ratios were usually 3.42 or 3.73 unless the truck was ordered differently - of which most selected 4.10s... but there were a few oddballs with 3.23s (more so in the 2wd v6 manuals).
i know factory 4.56 is in most RPO books, but i've only ever seen it on H3 hummers.
i'm pretty sure 99-04s had rear disk brakes, and the 05+ went back to drums.
personally for your presumed automatic, stock-ish tires, & basic (if any) mods, i'd go with 4.11s while installing the truetrac (reportedly a little sturdier than 4.10s due to having fewer gear teeth over the same size).
Yea unfortunately I’ve put up with the 3.42’s for a long time, about 16k towing miles, not really ever thinking about.
Yep, 4l60e, stock size tires.
I just put an LQ9 6.0 in the thing a few weeks ago and haven’t towed anything with it since.
It would spin the right rear way to easy before, if you were taking off from a stop even mildly quickly and crossed over the road paint that marks stop signs and intersections and also in the rain.
Now with the 6.0 it spins so easy it makes me afraid enough to do the truetrac that I’ve been threatening to do for 5+ yrs.
I believe you are correct in regards to the brakes, the buddies 04 v6 truck has disc and the other buddies 05 v8 truck has drum.
Oh that reminds me, so when I used to mess with s10’s a lot, I found a wrecking yard that had 2 s10 2wd’s that had 8.5’s so I bought them both.
One was disc and one was drum. The housing ends are different and you can’t swap brakes from one to the other. They won’t bolt up correctly.
Anyone know if that’s the case with these trucks?
Just curious.
Custm2500's Rude Friend
Just curious.
Just curious.
Disc brake oreintation
Drum brake oreintation
