+++ narrowing rear end advise++++
Old Dec 23, 2017 | 10:25 PM
Sosa454's Avatar
Old Dec 24, 2017 | 07:32 AM
matslp488's Avatar
Really nice wheels I like them...mine are 6in lip on the rear.. if yours are 5in I'm guessing I don't have to do any tubbing on my bed right??
Old Dec 24, 2017 | 07:46 AM
Sosa454's Avatar
Thanks. My back space is 4.25 and having dual piston caliper was challenging rotating them so they wouldn't hit the leaf spring. But it all fit without tub. I think a reverse lip 10" would need tubbing or I was told, and then of course a 12 would definitely need it. You would hit the leaf spring before the tubs. Are yours 10" wide? What's your back space?
Old Dec 24, 2017 | 08:41 AM
terravast4's Avatar
Originally Posted by Sosa454
nice truck. what drop you running with those 22's?
Old Dec 24, 2017 | 08:52 AM
Sosa454's Avatar
Thanks, it's only a 2 4.
Old Dec 24, 2017 | 10:01 PM
matslp488's Avatar
yes my wheels are 10" wide.... lip is 6" and bs is about 4"... mine is an SSS 2wd so I got drum brakes so it'll give me a little more clearance I think
Old Dec 25, 2017 | 06:31 AM
Sosa454's Avatar
You should be able to cut more and clear the fender better in case you want to go lower in the future. I would have to roll my fender if I want to go lower. I narrowed 2.5" so I could run a 2.5 spacer and use my stock wheels. I also did it for my front wheels and rear wheels would look like they lined up looking at them from the back. I had seen several narrowed trucks were the rear looked like it was sunk in to much, and the front look like it stuck out farther than the rears. I didn't like that very much I'm sure they did it for clearance. Good luck with your narrow it will look great once it's done.
Old Dec 28, 2017 | 08:57 PM
matslp488's Avatar
Thanks! I’m also planning on running spacers for my stock SS wheels hopefully I’m happy with the outcome... btw what size of lugnuts are you using??? I got 2in lug nuts and I don’t like the way they stick out of the wheel...looking for some like yours that don’t stick out of the wheels
Old Dec 29, 2017 | 06:20 AM
Sosa454's Avatar
MCGARD 65515, this is the part number I used and got another set of locks. They are 1.5" tall lug nuts.
jcroy454
Jun 17, 2012 07:10 PM
banker099
Aug 26, 2011 04:17 PM
KBOBOZ71
Jan 10, 2007 05:15 PM
TravisH
Dec 25, 2006 01:23 AM
