My z71 says do not dyno test !
Old Mar 6, 2005 | 11:57 PM
Default My z71 says do not dyno test !
under the hood a little yellow sticker says do not dyno. ??????????????
WHY?
Old Mar 7, 2005 | 12:23 AM
black_yukon's Avatar
Hmmmm! Maybe because it's 4WD?
Old Mar 7, 2005 | 02:04 AM
Maybe GM's afraid you will snap your driveshaft going 130 on a Dyno? You can dyno 4wd's just put it in 2 hi.
Old Mar 7, 2005 | 02:21 PM
04BlackGmc's Avatar
10 Second Club
A few people have postd this but my truck doesnt say it.
Old Mar 7, 2005 | 04:29 PM
Black02Z71's Avatar
The sticker is only on trucks with autotrac.
It says something like - "This vechile is equiped with an automatic transfer case, do not use on a 2wd dyno."
Old Mar 7, 2005 | 04:37 PM
parish8's Avatar
single digit dreamer
i thought this was an awd thing not an autotrack thing.
when you put it in 2wd the front diff disengauges so it should be fine but if you are real worried about it then pull the front driveshaft and there is no way anything can happen.
Old Mar 7, 2005 | 05:16 PM
04BlackGmc's Avatar
10 Second Club
I have autotrac also and no sticker..
Old Mar 7, 2005 | 07:27 PM
I didn't think I did either when I read this thread this morning...when I went to lunch I checked...sure enough, a little yellow and black sticker on the rad. support right between the batt. and the dr. side headlight.
Old Mar 7, 2005 | 07:52 PM
KeukaZ71's Avatar
i'll have to check mine too. i think by law or something, they are probably required to put that sticker on since it has 4WD capability
Old Mar 7, 2005 | 09:19 PM
8ALTNG's Avatar
Thats funny. i have a sticker that says "Do Dyno Test This Vehicle"
