my LVL6 65e compared to a stock 80e
Old Feb 17, 2011 | 03:53 PM
sharpshooter's Avatar
Default my LVL6 65e compared to a stock 80e
I've read a million threads on this but how do you feel my LVL6 compares to a stock 80e.Or if I ever go 80e should it be built also?
Old Feb 17, 2011 | 04:29 PM
TIM Z's Avatar
11 sec. Truck Mod
Thats what winter time and all the reading does, makes ya think.
My trans was just refreshed/rebuilt with all the goodies it can have ( 4L65E), But yet i wander also if i should have went 80E??
Im gonna run what i got and if it breaks then i believe an 80E with new clutches and shift kit oughta be more than enough.
Damn winter, makes us go crazy over thinking stuff!!!
Old Feb 17, 2011 | 04:35 PM
LS1TRUCKGUY's Avatar
everything ive seen says a stock 80e will blow a built 60e out of the water... from what i understand, the 80e has a lot more clutch surface
Old Feb 17, 2011 | 04:46 PM
my friend has blown 3 lv5's, you could always get a cheap 80e under $1k and run it, thats way less than paying $3k for a built 65e
Old Feb 17, 2011 | 06:36 PM
I should have given the history to my LVL6 in the original post first.
Also this is in no way meant to put down FLT [they have great customer service and build awesome transmission's].This truck is not my DD and gets run pretty hard when it is driven.
When I did the LQ4, cam & blower swap is when the LVL5 originally went in.It lasted for about 10k miles before the 3-4 clutch pack wore out but everything else held up great internally.So I sent it back to FLT and had it rebuilt and added the billet output shaft.This LVL6 lasted for about 5k miles and was sent back to FLT last Nov.It had the same issue as before.It lost the 3-4 clutch pack but everything else looked good.Chuck and Andy really helped me out on this rebuild and Chuck also changed a few things to help with my 3-4 issue.
The trans is back in my truck and only has about 50-100 miles on it.This is where my original post comes in.I've always wanted to avoid the 80e swap but I currently have a brand new LVL6 in my truck that I'm wondering should I sell now because I know it is in perfect condition and do an 80e swap.I probably could get the swap done with a stock 80e for the what I can sell my built 65e for but if I really need a built 80e that changes ****.
Or do I run the LVL6 with the new changes and hope for the best.I totally believe FLT builds a bad *** trans but I'm I at it's limits?
Old Feb 17, 2011 | 06:57 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I wouldnt trust a 60e built by anyone with the weight, size tires and pwoer youre running. I will be swapping back to an 80e myself at some point in time because I just dont trust the small parts that are in 60es.
Old Feb 21, 2011 | 09:02 PM
would a stock 80E do well in my set-up below?
or does it need a shift kit and clutches to live?
Old Feb 21, 2011 | 09:05 PM
GMCtrk's Avatar
I'd run it all stock.
Old Feb 21, 2011 | 09:20 PM
Mangled03gmc's Avatar
Baltimore Whore
I would at a min put a shift kit in it, just for haha's and a little bit of, a quicker shift.. Stock should be fine for you Russ.. I am in the same boat, but will decide once the 60 takes a crap.. Your weight is what is taking the toll on the trans, moreso then the power... I would keep your eyes out for a used 80, massage it a little bit...
Old Feb 21, 2011 | 09:35 PM
I pick it up this Friday man.
It has 75K miles on it so I'll see what kind of shape it is in.
