To much transmission fluid??
Looks like i overfilled my transmission by a good bit.. about a inch or 2 past the hot mark.. Do i need to drain out some? that drain plug is a booger.. any ideas??
I doubt it, the dipstick tube doesn't extend down into the fluid. You might be able to find some thin hose to put down the tube though.
And as stated above, if it's too full it will vent out the top of the trans and cover the entire underside of your truck with tranny fluid. Guess how I know...
Yes you can but be prepared to sit awhile! I did that by buying a hose small enough to fit in the dipstick tube and let it siphon. Took about 10 min/pint. Have a clear container so you can see how much you've pulled cause trans fluid tastes like
when you have to start the siphon again.
Basically It Should Still Hit The Same Part On Your Dipstick... Call The Manufacturer... Or Go On There Website And It Should List How Many Extra Quarts Capacity It Adds.... Start There... That Should Get You Close
Drill a little hole on the outside part of the drain bolt (dont drill into the pan obviously) then use a hammer and punch to spin the bolt loose. I've had to do this twice now, f**king lousy bolt. Good thing they're like 3 bucks each.
drummer0415
11
Oct 24, 2015 08:16 PM
ice17
Sep 22, 2015 05:18 PM
bluestang50
Sep 21, 2015 08:36 AM
