mph loss with tc?
Agree with bill. You will pick up MPH in 1/4 because of the shift extensions letting you stay in higher rpms.
That's the entire point of the stall.
You shouldn't lose MPH with a Stall as it's only designed to keep you into the rpms that produce power. More power = more acceleration.
Gears however affect how easily you can get off the line and can affect your MPH.
If you have 3.23's you get off the line a bit slower but you can hold 2nd gear all the way down the track. With 4.11's you'll likely be shifting into 3rd a lil over 1/2 way down the track and start to lose a little bit of momentum over 2nd gear's pull.
Does that make sense to anyone else? That's how I've looked at it. Input?
