max power for a 4wd
Old Oct 2, 2008 | 04:47 PM
thunder550's Avatar
High on diesel fumes
Should be about the same.
Old Oct 2, 2008 | 05:26 PM
Thanks dude you are the man... I found me an awd SSS. I am excited!!
Old Oct 2, 2008 | 05:48 PM
exodus's Avatar
Do any of you think that this would hold true for a 97 z71 transfer and diffs? I will be doing a turbo 408/ 4L80E combo next year, and have been wondering if the transfer and the front axle more so than the rear would hold up to the 600whp abuse.
Old Oct 2, 2008 | 06:23 PM
thunder550's Avatar
Don't quote me on this, but I think it's the same transfer case that's in the newer trucks. New Venture Gear, or New Process Gear or whatever. Someone needs to back me up on this though.
I remember seeing a site one time that had the NP246 (I think that's the Autotrac case) rated at something like 2500lb-ft. I tried to find it again but couldn't.
Old Oct 2, 2008 | 09:29 PM
Spoolin's Avatar
GFYS and STFU
PM 04chase for more info!!
Old Oct 2, 2008 | 10:25 PM
ForcedTQ's Avatar
You are correct sir!
Old Oct 3, 2008 | 08:53 PM
exodus's Avatar
just tryin to make sure before I go through with all of this and grenade the bastard!
Old Oct 3, 2008 | 09:20 PM
2004SSS's Avatar
mine has lasted a bit i have the awd ss. stock diff's the rear has been studded, and has a girdle for insurance. trans has been out a time or two but holds up now. last time i dynoed mine with the front shaft pulled i made about 700 rwhp . i should be able to make 800+ now with out a problem .
Old Oct 5, 2008 | 07:53 PM
Beatdown Z's Avatar
Laid Back
Yep, there badass little t-cases, when my truck had 35's with 3.73's it would pull the left front tire off the ground a few inches when manually shifting from 1st to 2nd in 4Lo
Oobray
Jun 13, 2022 03:38 AM
silverstreak07
Jun 28, 2016 06:29 PM
gaps
Sep 2, 2015 01:19 PM
05GMC4.8
Aug 7, 2015 09:55 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
