manual trans
Old Aug 17, 2006 | 09:05 PM
4.8_5speed's Avatar
Default manual trans
Hello
What all does it take to adapt my 2000 gmc trucks 5 speed trans to a 5.3 or 6.0 engine.
Joe
Old Aug 18, 2006 | 06:40 AM
hirdlej's Avatar
Nothing, just take your motor out and drop the new one in. Nothing special required at all.
Old Aug 18, 2006 | 01:37 PM
Barras's Avatar
Do any of yall 5 speeders have a problem with the 2-3 shift or know of anythign failing causing it to hate the 2-3 shift? My buddies Regency usually will not make the 2-3 shift under high RPMs.
Old Aug 18, 2006 | 06:00 PM
nojpsht04rst's Avatar
Barras. I just recently started having problems during the 2-3 shift. I wound up blowing my throw out bearing monday night doin a 2-3 at high rpm.
Old Aug 19, 2006 | 08:54 AM
4.8_5speed's Avatar
thanks for the info. That is what i was hopping for. yea i sometimes have a problem with my 2-3 shift at higher rpms. i would like a t56 but it is out of my price range at the moment.
Old Aug 19, 2006 | 09:09 AM
TurboGibbs's Avatar
There is obvioulsy a problem with the design of the internal shifting rails. I and my friend have had problems with this.
Old Aug 19, 2006 | 09:13 AM
4.8_5speed's Avatar
how long do you think my transmission will last behind a 6.0 with cam and headers
Old Aug 20, 2006 | 01:01 AM
SBTork's Avatar
The 2-3 shift is a b*tch. Mine has 2700 miles on it and from the sound of it, it looks like it will always have that hard shift. I thought because mine was new it was so tight it would not go. Has anyone seen an improvement with an aftermarket shifter like a hurst or something?
Old Aug 20, 2006 | 11:03 PM
TURBO8's Avatar
I had a problem with my 5 speed the next day after I bought it. It would just pop out of first gear at the light. It would do it on a hill, and I would almost hit the car behind me. I took out the 5 speed asap, and put the 6 speed in. That was one of the best things I did to the truck, other than the turbo. mjhoward made good power with the 5 speed, 400 plus to the wheels, ran 12's with it. A stock 6.0 will not put out those numbers, if he can do it, maybe you can. I am getting lucky on my stock 6speed. I thought it wouldn't take the weight of the truck, hell it's taking the weight and 600 plus HP almost 700tq to the wheels. No signs of breaking yet. sometimes you just get lucky.... Good luck!
Old Aug 21, 2006 | 09:51 AM
RERICK's Avatar
I have a Hurst shifter . 1st. to 2nd. is better but 2nd. to 3rd. is still a bitch. I agree with MJhoward , I think it is in the design of the trans.
Ron
