Lowered 4x4 and AWD owners, please come in...
Old Mar 10, 2009 | 01:56 PM
  #21
newcastle3's Avatar
Can somebody please list the correct GM Part #'s for the HD Keys and the 2WD U-Bolts?
Old Mar 10, 2009 | 02:12 PM
  #22
1_fastsilverado's Avatar
Originally Posted by JAVI05
has anyone used any autozone pullers for this? i see alot of them but which one. i was told a 7 ton puller? will anything else work? thanks
I used a 7 ton 2 jaw puller on mine. It's really easy to do, jack the front of the truck up (you can do one side at a time, but I did both right away), take off the front wheels to make it easier, put a jackstand on each side under the frame rail not the lower control arm, then hook a jaw on each side of the torsion bar crossmember and use the bolt in it to push up the key. (there will be a small indent that the tip of the bolt will sit in) Next take out the key adjuster bolt and pop out the little insert the bolt goes through. (don't use your fingers though just in case!) Now you can release the puller and take it off, leaving no tension on the bar. Pop the bar out of the center of the key, put the new key in place, slide the bar back through and reverse the previous steps to get the adjuster bolt back in. You can PM me if you have any ?'s...hope this helps.
Old Mar 10, 2009 | 02:47 PM
  #23
red87iroc's Avatar
keys = 15045171 (purple keys)
2wd UBolts = 15002781
Old Mar 10, 2009 | 04:09 PM
  #24
JAVI05's Avatar
thanks.. 1 fast silverado.
Old Mar 10, 2009 | 04:26 PM
  #25
Kylemsu720's Avatar
Can someone post a complete list of everything you need for a 4/6 drop on an NNBS 4wd?
Old Mar 10, 2009 | 04:28 PM
  #26
newcastle3's Avatar
Thanks for the info.
Forgot to ask, are these per bolt and key?
Old Mar 10, 2009 | 05:23 PM
  #27
red87iroc's Avatar
Yep, need two keys and four ubolts.
Old Mar 10, 2009 | 09:30 PM
  #28
006rcsb's Avatar
check this out
http://www.silveradoss.com/forums/in...howtopic=22102
Old Mar 11, 2009 | 07:13 AM
  #29
JAVI05's Avatar
thats about the best pic and instructions ever! i cant wait to finish my truck. pics when done. thanks.
GXPJAY
Feb 13, 2022 08:15 AM
Vash3233
Sep 22, 2019 01:18 PM
Corvette454l88
Sep 1, 2016 01:24 AM
Three6GMC
Aug 28, 2015 07:56 AM
85SS/85GN
Aug 7, 2015 04:30 PM
