Lower control arms or spindles?
Old Jan 14, 2016 | 09:02 PM
4xRCSS's Avatar
Registered User
Default Lower control arms or spindles?
Looking at options for lowering the front end. I have a '99 rcss 4x4. It will be boosted and will be 4wd launched. Curious what you guys have for setups and what your shafts angles are. The djm lower arms allow for a 3" drop and the spindles only allow for 2", which do you think would be the better option?
Old Jan 15, 2016 | 04:52 AM
mikeyjm1's Avatar
I'm probably 2" lower right now on Atomic's Coil over conversion and its great. I may still go lower, it'll be with spindles to keep from changing anymore suspension and steering angles than needed.
Old Jan 15, 2016 | 07:07 AM
4xRCSS's Avatar
Registered User
My goal is 3-4" in the front, maybe spindles and a 1-2" lowering key to adjust on the fly. I know that will throw off the alignment but ill manage. I live in new England and the roads are **** already, so no need to make the ride any more uncomfortable.
Old Jan 15, 2016 | 07:25 AM
mikeyjm1's Avatar
You may not need the keys for an inch or two. I'd do spindles first then see what you still want and can adjust from there, before spending more for the keys.
Old Jan 15, 2016 | 08:09 AM
Atomic's Avatar
I have a gauge for that
Coilovers! You can get up to 4-5" drop with just coilovers on stock spindles and LCAs, and it will ride way better than drop keys. Check out the threads in my sig or send me a PM for more info.
Old Jan 15, 2016 | 09:24 AM
4xRCSS's Avatar
Registered User
Not looking for anything more than 3-4" and a flat cv
Old Jan 15, 2016 | 09:41 AM
Atomic's Avatar
Yea 2-3" is flat CV, but you really want slightly negative so when the front end rises a bit the cv is flat then. This is how mine sits. I was just saying you could get up to 4-5" of drop if you wanted, but you can basically go from 5" of drop to ~4" of lift depending on what shock and spring you use. I will be glad to help you pick out what you need.
iDEALS1
Jan 20, 2016 03:35 PM
Blwn99x
Jan 20, 2016 09:44 AM
redz71truck
Jan 14, 2016 11:46 AM
LOBO2
Jan 13, 2016 11:24 AM
vmaxpro
Jan 11, 2016 04:16 PM
