4l60e sunshell clearance
Old Jan 14, 2016 | 09:49 PM
Mtm2015's Avatar
Registered User
Default 4l60e sunshell clearance
Looking for some advice here if anyone can shed some light. Pulled a buddy of mines transmission down (smoked the 3/4s) for rebuild. Going back together got to the half way point of the output shaft snap ring. Snap ring went on perfect but when spinning the output shaft it spins one way fairly easy however the sunshell drags on the case somewhere. Trying to spin the output shaft the other way is nearly impossible without using a rag between the shaft and your hand. When it does turn that way, it seems like it gets hung up. Any ideas what it could be? I've done probably ten 4l60e and about 5 or 6 700r4's over the years and have never seen anything like this. Only thing I can think of is maybe the rear case bushing is crooked. If anything else was off down the line the snap ring wouldn't be installed. Correct? Thanks for any help!
Old Jan 15, 2016 | 10:18 AM
Wolftrk99's Avatar
Sounds like an issue with the center support/rear sprag...output shaft should be fairly tight in one direction and easy in other... Had similar issue with my build but wasnt until i installed pump, found out my selective thrust washer was too thick and putting too much pressure on the input drum with the pump installed...
Old Jan 15, 2016 | 02:10 PM
Mtm2015's Avatar
Registered User
It turned out to be the anti clunk spring out of position! I spun it a few times and it made witness marks on the sunshells edge. Thank God it was something simple!
Old Jan 15, 2016 | 03:52 PM
Wolftrk99's Avatar
Rather catch it now than later
Old Jan 15, 2016 | 04:50 PM
tgui's Avatar
Just like an STD!
blcksierra
Jan 19, 2016 06:42 AM
Aboss
Jan 17, 2016 11:15 AM
Go5.3tt06
Jan 14, 2016 11:41 PM
ss4chad
Jan 13, 2016 10:22 AM
rayfrausto
Jan 9, 2016 02:57 AM
