Lost lockup reading code PO894??
Old Sep 17, 2012 | 09:17 AM
03regcab sierra's Avatar
Default Lost lockup reading code PO894??
Getting a PO894 code saying transmission component slipping and i no longer have lockup.. Is my converter bad or my trans goin out?
Old Sep 17, 2012 | 12:36 PM
Anyone?
Old Sep 17, 2012 | 05:12 PM
1FastBrick's Avatar
Custm2500's Rude Friend
How does the fluid look???
Old Sep 17, 2012 | 05:41 PM
Ill check fluid tonight. Trans temp went up to 220 just cruising on a short drive while its normally at 170-180
Old Sep 17, 2012 | 08:22 PM
Oil looks and smells like new.
Old Oct 1, 2012 | 08:57 AM
Tried to manually lock up with hp tuners but no luck.. Is my converter bad?
Old Nov 13, 2012 | 02:07 PM
2slowrado's Avatar
My 80e is doing the same thing. And im on my 3rd converter. Not sure what the problem is. Im gonna bring mine to a trans shop soon if I cant figure out what the deal is
Old Oct 16, 2013 | 10:21 AM
R'Addiction's Avatar
Registered User
Has anyone come up with anything on this issue? TCC solenoid? 06 Trailblazer with po894 and shifts hard. Fluid looks good nothing in the pan. Thanks.
Old Oct 16, 2013 | 10:45 PM
TechGM's Avatar
Registered User
Ok. Can your tuner see TCC slip speed data? If so, clear code and watch TCC slip speed while going into lockup or trying. See if it shows slip speed decreasing or not changing much at all. But more than likely your torque converter has had it's time. This is also another check to look for, remove the TCC enable solenoid and air check it. This is the Solenoid that bolts into the pump. Some of these solenoids have been known to get hairline cracks running down them.
Same goes for you R'Addiction and that 06 trailblazer of yours. If you do find that this is the cause you will need to buy the whole internal trans harness as the solenoid is hard wired. No connector. Let me know what you find
Old Oct 16, 2013 | 10:56 PM
TechGM's Avatar
Registered User
Damn. Just read that you have a 4L80E in your truck 03regcab sierra. You're more than likely looking at a torque converter. 4L80E trans go through converters like nobody's business. Even on stock form trucks. Otherwise you have to remove your trans and pump and check the TCC valves in the pump to see if they move freely or if they are stuck. The only other thing I can think of to check is the TCC PWM solenoid to make sure it is actually working. Really hard though without scan tool unless your tuner can gradually command PWM?......
blowngmc
32
Oct 12, 2017 11:59 AM
murderedSS
27
Oct 12, 2015 11:13 AM
MA$TER_E
Sep 9, 2015 03:14 PM
silver-mod-o
Sep 7, 2015 10:22 PM
muncie21
Sep 7, 2015 09:55 PM
