Looking for advice on my 4L60E
Old Jul 12, 2012 | 04:09 PM
Tkosinski2's Avatar
Default Looking for advice on my 4L60E
So like it says I'm looking for advice on my trans. The truck is a 2000 2wd extended cab silverado 1500 with a 5.3L in it. I currently have a Volant cold air and am getting tri y's on soon with a blackbear tune and a vette servo. My trans has 160K miles on it and I've gotten a code twice that went away for trans component slippage. It only happens when I'm hauling stuff in hot weather. Heats up the trans and yeah I get some seriously hard shifts I don't like. Anyway I figured id start looking into what parts are common to replace or upgrade. I'm not looking to go crazy with shift kits and all that but I herd to get "the beast" sun shell. Was looking into maybe some advice on things like that that will make towing with my truck more reliable an such. Thanks guy!
Old Jul 12, 2012 | 04:21 PM
.James.'s Avatar
I would invest in a Tru Cool 40k transmission cooler, smart investment. I love mine and love seeing that my temperatures are lower.
Old Jul 12, 2012 | 06:43 PM
Tkosinski2's Avatar
I have the stock external trans cooler on the truck originally. I really only got the code on long hauls in 90+ degree weather.
Old Jul 12, 2012 | 10:57 PM
Foxxer's Avatar
Ditch the stock cooler, as stated Tru Cool 40k would help reducing temps. Two things that kills a trans, heat and weight.
Old Jul 13, 2012 | 12:13 AM
TX Tahoe Z71's Avatar
+1. About 4 times bigger than the stock cooler. And get a Sonnax billet OD servo since you will be towing, it increases apply pressure in 3rd and 4th to reduce slippage and heat. About $100 and installs with your vette servo.
Old Jul 13, 2012 | 12:23 PM
Tkosinski2's Avatar
Cool so throw on the list a OD servo. Should I even bother with "the beast" sun shell? Also what rebuild kit is quality? I know once I take it apart that I will need to inspect the planetaries but I would like to have some parts ready for me.
Old Jul 13, 2012 | 12:24 PM
I would install the servos and cooler first, as neither need the trans pulled, then go from there.
Old Jul 13, 2012 | 01:05 PM
Tkosinski2's Avatar
Do they have a larger cooler that works with the factory lines? Like a direct swap?
Also with the OD servo do you have to adjust the length of anything?
Old Jul 13, 2012 | 01:21 PM
Direct swap, use your existing lines. Do a search on here and there are a few write-ups about it, but it's really easy. Use two hose clamps for each line as they are pressurized (30 psi IIRC).
Nope, just swap and go. I used my stock pin.
Old Jul 14, 2012 | 06:29 PM
Vince B's Avatar
If you are getting a PO1870 code I would suggest addressing the TCC regulator/isolator bore in the valve body. With the miles on the trans I'm sure its on the worn side. Its some thing that I would address with either an overhaul or a repair at this point. There are a few different ways to go about this. Blocking the valves, installing a different valve set up from the after market or replacing the valve body itself are really your options. Most shift kits will address this issue so I would not rule out installing a shift kit. Both the sonnax kit and the transgo kit address this circuit. Hope this helps. Vince
