long trans cooler installed
Old Dec 5, 2008 | 07:52 PM
006rcsb's Avatar
Thumbs up long trans cooler installed
i finally got my trans cooler installed today, i went to autozone and got some pre flared tubes bent them and cut them to work with the stock lines, and i used nut and ferule tube couplers to connect them to the stock lines. I did cut the stock lines, but if i sell the truck ill just get a couple more nut and ferule couplers and couple the stock lines back together, so i can keep my cooler.
Old Dec 5, 2008 | 08:05 PM
95 bright teal's Avatar
Looks good! did it come with the brackets? Thats something i need to do soon
Old Dec 5, 2008 | 08:23 PM
006rcsb's Avatar
Yep it came with a whole bag of stuff including those brackets and brass hose barb fittings and a rubber hose that i didnt use, I borrowed a tubing cutter and bender, and I got the couplings from work (freebie). The pre flared line that i got from autozone was only 5.49. I used the factory bolts for the brackets and then just a couple of 1/2 inch long 1/4-20's to bolt the cooler to the brackets, it only took about a half hour to install.
Old Dec 5, 2008 | 08:27 PM
cool! Good info here thanks for sharing. actually cleared a few things up for me.
Old Dec 6, 2008 | 10:22 PM
budhayes3's Avatar
PT's Slowest Truck
Looks real good, I like how you have it plumbed with hard line all the way...good to know that the tubing is so cheap too, I may consider this route in the future.
Old Dec 7, 2008 | 12:14 AM
006rcsb's Avatar
i cant say that its plumbed hard line all the way, because there is still rubber hose in the factory lines, but hopefully it wont leak. As far as it goes there is no more rubber hose there than factory.
Old May 5, 2009 | 07:02 PM
black06's Avatar
do you remember what the thread size was on the pre flared tubing? I'm assuming the tube itself was 3/8
Old May 5, 2009 | 07:12 PM
dry_kill's Avatar
where did you get the cooler from?
Old May 5, 2009 | 07:42 PM
006rcsb's Avatar
i picked it up on ebay i forget the sellers name, but i think it was around 115$and came with a bunch of stuff i didnt use.
Old May 5, 2009 | 08:44 PM
00Silv4.8's Avatar
awesome, nice install too, I need a cooler as well
ullose272
Aug 5, 2016 02:05 PM
1slwgto
Aug 16, 2015 06:40 PM
therock
Jul 25, 2015 09:23 AM
ullose272
11
Jul 17, 2015 07:22 AM
ferrellrooster
Jul 17, 2015 07:07 AM
