Locking TC in 4l80e
Old Nov 21, 2010 | 02:02 AM
foose04's Avatar
Default Locking TC in 4l80e
I'm running a manual valve body so currently only thing hooked up to the transmission is the speed sensor and B&M shifter. Is there any way I can use HPtuners to send a signal from the ECU to the transmission to lock and unlock to convetor? I know I have all those tables to play with, but currently dont use them.
Any one know what pins controll the TC on the ECU side and trans side? Would there be a plug in harness I can use? Truck came with a 5speed.
Thanks
Old Nov 21, 2010 | 06:18 PM
MikeGyver's Avatar
Originally Posted by foose04
I'm running a manual valve body so currently only thing hooked up to the transmission is the speed sensor and B&M shifter. Is there any way I can use HPtuners to send a signal from the ECU to the transmission to lock and unlock to convetor? ...
Not without some more wires plugged into the trans.
Old Nov 21, 2010 | 07:05 PM
Wilde Racing's Avatar
How do I change this text
Depends on how you want the TCC to function, with slip? instant on? You will need wires. Does your valve body have provisions for a tcc solenoid?
Idryfly5
Sep 2, 2022 08:55 PM
jscherbs
Mar 24, 2017 07:20 PM
dselby25
Sep 11, 2015 05:03 AM
97aztecgt
Sep 10, 2015 05:07 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
