P to D hard bumb.. y????
Old Nov 21, 2010 | 07:37 PM
05gmcsierra's Avatar
Default P to D hard bumb.. y????
hey guys just one quick question.. after i installed my shift kit a couple months ago when i put my truck in reverse or drive or anywhere i put it other than N it has a hard hit. i know it must of been something with the shift kit install but what??? im rebuilding my tranny may b in two weeks since it went out on me not to long ago and i have no 2 or 4 so i was thinking that i would fix that problem. it doesnt bother me but i would like for it to be a bit smoother. any ideas? i have the hd-2 shift kit. all holes got drilled with the smaller bit that was supplied and one washer was used only.. which i will be taking off since my 1-2 shift was tripping tires at 3500rpm and really letting them loos at 6k
Old Nov 21, 2010 | 09:08 PM
mhotrodscooter's Avatar
Slack in u-joints or diff?
Old Nov 22, 2010 | 01:31 AM
Weird I didn't touch diff when I installed the shift kit. And it only started doing it after shift kit install but ill defanetly take a look into that..
Old Nov 22, 2010 | 02:19 AM
smokeshow's Avatar
Mod with training wheels
What converter do you have? If its more than a few hundred RPM stall over stock, then it shouldn't hit as hard during any shift because not as much torque is being applied when you're idling. If you have a higher stall converter, then drivetrain slack may be to blame. When you start shifting a little harder, it tends to stress/possibly loosen things a little bit.
Old Nov 22, 2010 | 02:44 AM
yeap that makes perfect sense.. i did the shift kit the day i did my converter install.. its a circle d 3200..and if it were to be true what can be done to lower the hard bump that im getting?
Old Nov 22, 2010 | 03:44 AM
Find where the slack is coming from.. Go from there..
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
slocaddy
Sep 25, 2015 12:42 PM
Tuckin15s
Sep 23, 2015 09:35 PM
