locker not locking
Old Aug 31, 2005 | 10:52 AM
rumblebox's Avatar
Default locker not locking
other than being broken, are there any causes for our lockers not to lock when you want them to?
old fluid, wrong fluid, one wheel gaining momentum too quickly for the other one to lock in???
Old Aug 31, 2005 | 11:01 AM
Is it the stock G80?
Old Aug 31, 2005 | 11:14 AM
rumblebox's Avatar
yes, with 132k
Old Aug 31, 2005 | 11:16 AM
three83's Avatar
I think that is the problem stock g80 with 132k. It's just wore out. Put an eaton posi unit and be done with it.
Old Aug 31, 2005 | 11:20 AM
rumblebox's Avatar
how much money, and how much of a PITA?
Bish's Avatar
Originally Posted by rumblebox
yes, with 132k
Only problem I could think of is if your wheel is spinning above 20mph as the locker won't lock over 20mph I believe. If you punch it from a stop and get wheel spin above 20, the locker won't lock.
I would try it on a slippery surface. If it locks with slow wheel spin, it is working properly. I've got 148K on my G80 and it still works well.....as good as can be expected from the stock unit. Mine has lived on Mobil 1 gear lube every 25-40K since new.
Old Aug 31, 2005 | 11:25 AM
rumblebox's Avatar
that's kinda what i was thinking. if i light'em up going straight THEN turn it'll stay locked, but if i punch it while turning hard and get one wheel spinning really quickly it wont lock.
Old Aug 31, 2005 | 12:07 PM
Mort's Avatar
Cool
You will probably break it if you get it to lock turning them hard in a turn on dry pavement. The force of being locked and one wheel having to go faster than the other will create more force than the G80 can sustain and the case is liable to break. Not so much of a problem on loose or wet surfaces when the outside wheel can slip a little to make up for the longer distance it has to go.
Alco
Jul 20, 2016 04:53 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
Cammed4ever
Sep 30, 2015 03:38 PM
JoshH
Sep 28, 2015 11:19 AM
