line locking
Old Jul 5, 2006 | 01:03 AM
jus1975's Avatar
Default line locking
I have a 04 VHO Sierra. It will not line lock at all. Yo know when you hold the brakes and give gas. That is embarrasing and scary. Is that the torque managment at work or what.
Old Jul 5, 2006 | 09:10 AM
Colby 04's Avatar
that's called power braking.......a line lock is a device used to lock the front brakes for the burnout.
Yes, that's probably TM preventing you from doing burn outs.....a tune will take care of that.
Old Jul 5, 2006 | 04:56 PM
jus1975's Avatar
Ok thats what I thought. Here is what I have or supposed to have.
LQ9 engine
K&N Intake system
80mm TB
comp cam 224/228 581 lift
pro magnum rollers, comp 918 springs, comp pushrods
pacesetter headers
true dual setup with twin 18' magnaflows dumped
And a tune from Nelsons performance and I stated I wanted all TM removed.
How can you verify if everything is done the way you want.
Old Jul 5, 2006 | 05:14 PM
Colby 04's Avatar
I'm not sure, but shouldn't you have a higher stall converter coupled with that specific cam? If you don't, that may be why you don't have the lowend there to do a burnout?
Old Jul 5, 2006 | 06:55 PM
negativeswitches's Avatar
yeah and you might want an line lock just to save your trans, i have the biondo one from summit, works great!!!
Old Jul 5, 2006 | 08:44 PM
DrX's Avatar
DrX
Make sure that "Brake Torque Management" is also disabled in your tune. BTM reduces engine power on ETC vehicles when your foot is held on the brake.
Old Jul 6, 2006 | 01:01 PM
jus1975's Avatar
Yeah I do have a higher stall converter just haven't installed it yet but the truck should have enough to turn the wheels over. Hell my little 2.8 S-10 had enough to turn the tires over.
Old Jul 6, 2006 | 01:23 PM
Colby 04's Avatar
but your 2.8 S-10 prolly had 4.10's and a stock cam.
Idryfly5
Sep 2, 2022 08:55 PM
Tim94gt
23
Sep 18, 2015 04:51 PM
dselby25
Sep 11, 2015 05:03 AM
97aztecgt
Sep 10, 2015 05:07 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
