Leveling out 05 RCSB Z71?
As you can see in the pic below, my truck sits signifigantly lower in the front than in the rear (looks like at least 2", but I haven't measured on level ground yet). What options are available to raise the front an inch or two? Will the torsion bars allow that much adjustment, will I need the Ford keys, or what?
Thanks, Shawn
Thanks, Shawn
Originally Posted by KySilverado
I went the other way. I put 2" drop shackles on the rear. Same ride, no alignment.
Originally Posted by 02BlueStepside
Don't the z71s has lift blocks? I thought you could just take the block out from between the springs and axle and it would even it out. All you would have to buy is the 2wd ubolts that are a little shorter.
