Let's talk tires - Best balancing, smoothest riding-(nitto-falken-kumho-yokohama's)
Old Jan 25, 2005 | 11:49 PM
  #21
moregrip's Avatar
what a rush!
Originally Posted by hirdlej
Are you referring to your new BF Goodriches? I just looked them up on the tirerack and they're damn expensive. About $219 a piece to be exact
yes, my big *** 305/50-20's on Intro Pentia 8, 20x10's. IMO, thats alot of wheel tire to balance as well as they did.
they ain't cheap
Old Jan 25, 2005 | 11:52 PM
  #22
hirdlej's Avatar
But these are the GM silverado ss rims. They should be more true than most aftermarket rims. Oh by the way, on my factory 8.5" wide rim. what's the widest tire I can fit? I was hoping to be able to squeeze a 295-45-20. But looking at the mfg suggested size, it's stating the narrowest rim you can use on a 295 tire is a 9.5-11 inches. Would you agree or disagree with this statement?
Old Jan 25, 2005 | 11:55 PM
  #23
moregrip's Avatar
what a rush!
On a 20x8.5" wheel you can fit a 305/50-20. That's a 32" tall tire.
And I beleive that's the Max. if you go by the tire mounting specs
Old Jan 26, 2005 | 12:01 AM
  #24
hirdlej's Avatar
I want shorter, and the 295-45-20 is the exact height I want 30.5 inches and NO TALLER. If you can squeeze a 305-50-20 on a 20x8.5 rim, you can squeeze a 295-45-20 just fine, right?
Old Jan 26, 2005 | 12:05 AM
  #25
moregrip's Avatar
what a rush!
Nope, at least if you follow the wheel mounting specs.
The largest 30.5" tire rated for an 8.5" wheel is a 265/50-20 that I found.
Old Jan 26, 2005 | 12:07 AM
  #26
hirdlej's Avatar
Then it wont be as wide as as the factory tires even
Old Jan 26, 2005 | 12:08 AM
  #27
moregrip's Avatar
what a rush!
It will be wider, section width on that tire is 10.9"
Old Jan 26, 2005 | 12:10 AM
  #28
hirdlej's Avatar
it'll be wider than a 275-55-20 tire even?
  #29
moregrip's Avatar
what a rush!
oh, my bad, 265/50-20 is the stock tire?
Those 305/50-20's would fit the wheel
Old Jan 26, 2005 | 12:12 AM
  #30
moregrip's Avatar
what a rush!
No, section width on that is 11.1"
However the 275/55-20 is a 31.8" tire
that 305/50-20 is 32" and is wide as ****.
