Leaf spring front hanger replacement
Old Mar 31, 2015 | 11:09 PM
thunder550's Avatar
High on diesel fumes
Default Leaf spring front hanger replacement
The left hanger on my 99 1500 has some fubar'ed bolt holes. Does anyone make a stock replacement? I've seen plenty of drop hangers, but not a OEM replacement. I only need the driver's side, passenger side is fine.
Old Mar 31, 2015 | 11:16 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The dealer does.
Old Mar 31, 2015 | 11:17 PM
thunder550's Avatar
Yeah I just found GM PN 12474018. Thanks.
Old Mar 31, 2015 | 11:19 PM
1FastBrick's Avatar
Or you can go used...
I would have to see if the extended cab front leaf mount is the same as a regular cab. If it is, I may know a guy that might have some used ones....
Old Mar 31, 2015 | 11:26 PM
1FastBrick's Avatar
12474018 LH front
HANGER KIT,RR SPR FRT - LH. Required: 01
LHD. For: CK157(03-53) (1999-2007) (2001 - 2007).
12474019 RH front
HANGER KIT,RR SPR FRT - RH. Required: 01
RHD. For: CK157(03-53) (1999-2007) (2001 - 2007).
12474015 Hanger kit 1st Design
HANGER KIT,RR SPR FRT(W/FRAME 15761848 JSN LABEL OF 20487599. FOR 2ND DESIGN SEE 88982586). Required: 02
HANGER KIT,RR SPR FRT(W/FRAME 15761851 JSN LABEL OF 20493884. FOR 2ND DESIGN SEE 88982586). Required: 02
For: C159(03)(1ST DES) (1999-2001) (2001 - 2001).
For: C159(53)(1ST DES) (1999-2001) (2001 - 2001).
88982586 Hanger kit 2nd design
HANGER KIT,RR SPR FRT. Required: 02
HANGER KIT,RR SPR FRT(W/FRAME 15761848 JSN LABEL OF 20487600. FOR 1ST DESIGN SEE 12474015). Required: 02
HANGER KIT,RR SPR FRT(W/FRAME 15761851 JSN LABEL OF 20493885. FOR 1ST DESIGN SEE 12474015). Required: 02
For: C159(03)(2ND DES) (1999-2001) (2001 - 2001).
For: C159(53)(2ND DES) (1999-2001) (2001 - 2001).
For: CK159(03-53) (2002-2007) (2002 - 2007).
Old Mar 31, 2015 | 11:29 PM
Gadgetized's Avatar
If they are over priced, let me know. I have mine from when I removed my originals. They are in very good condition. Never seen a winter.
Old Apr 1, 2015 | 12:16 AM
thunder550's Avatar
How much do you guys want for them? They are pricey new. My zip is 85027.
Old Apr 1, 2015 | 12:33 AM
thunder550's Avatar
This is the front drivers side btw.
Old Apr 1, 2015 | 12:37 AM
1FastBrick's Avatar
I would sale a set for less than the price of 1 new from GM.
Since his are already off and ready to go, let him respond...
If you want to pick a set up on your road trip let me know. I would have to remove a set on a weekend.
Selling 1 on it's own would be worth less, as finding a guy to take the other side would be like finding a needle in a haystack. Usually the guys that want to put a lowered truck back to stock are looking for a set. Same with the guys repairing rusty frames.
Old Apr 1, 2015 | 05:10 AM
Gadgetized's Avatar
PM sent
