just ordered my 4.11 and tru-trac!!
I did about 5 heat cycles on mine and then let loose on them. Just yesterday I changed my gear oil, and after doing it i would NOT recommend changing it (if using OEM AAM gears as I did - I've read these are also heat treated to 1500 degrees at the factory and do not require a break in period like aftermarket gears). The oil was clean clean clean with nothing in it. I never changed my stock rear end oil for nearly 150k with no problems, but I went ahead and did it just because everyone here says do it...
What kind of oil do i need to run in the rear end to break them in? after the break in period what oil should I use?
for anyone who uses HP Tuners, Once a truck is registerd with them can it be used on any hp tuners program? Dynospeed tuned my truck with HPtuners and one of my friends has a laptop with hptuners that works at the shop thats putting everything in tomarrow, can he change the shift points and stuff?
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
