Just got a 6L80 but need some help
Old Feb 22, 2010 | 11:48 AM
ig109's Avatar
Im working the same topic.. check my threads.. Apparently the whole engine harness needs replaced as well as driveshaft (s) and the shifter on the column.. Then needs tuned to reflect having a 6L..
Lots to it..
Old Feb 22, 2010 | 02:03 PM
denali-08's Avatar
you dont need the column shifter, stock will work.
Old Feb 23, 2010 | 11:17 PM
Mang213's Avatar
Seems to be a bit involved, but not too bad. With the stock shifter you cant utilize the manumatic shifting, right? Doesnt the 6 spd shifter have a rocker switch to go thru the gears, as opposed to the tow/haul button? Also, what about the gauge cluster display? Will a tune reset the computer to reflect the change to a 6 spd on the display, or does it need to be replaced with the proper unit?
Old Feb 25, 2010 | 09:16 AM
shupe's Avatar
Subscribed...
Old Feb 25, 2010 | 09:32 PM
denali-08's Avatar
tow haul button will work but the 123 gears on cluster dont, and the stock shifter does not have manual shift, so if you want all that options go with the escalade-denali shifter, or stock will work
Bumpers
Aug 4, 2024 09:44 PM
TAPyvehc93
Dec 27, 2015 12:14 PM
Chevy305
Sep 28, 2015 09:21 PM
jtphelps289
Sep 11, 2015 06:37 PM
Jake75
Aug 16, 2015 07:06 PM
