Just got a 2/4 drop on my ECSB
Nothing is wrong with Belltech. They sell very high quality pieces. As for the McGaughys stuff, the kit is correct. The spindles are 2" drop, the leafs are 2", and the shackles are adjustable 1-2". This is what is on my crew cab. I believe the new leafs have a higher spring rate. There is no overload spring and i can still haul as much as before.
I have mcgaughys kit on my truck and am very pleased. I had NO fitment issues what so ever. They don't rub, I didn't loose any turning radius.....matter of fact, if you put them next to the GM spindles they look identical with the exception of the bearing hole being further up on the spindle. Maybe that has something to do with Mcgaughys winning an award at SEMA from GM for their spindles
I have used belltech spindles in the past with great success (79 chevy truck) but I think Mcgaughys has them beat with the NBS trucks.
PT's Slowest Truck
The guys over at SilveradoSS.com seem to favor the Belltech's over the McGaughy's...I think a few of them have had problems with the McG's. Haven't heard too much negative about them over here though. I've seen side by side comparison pics, and both seem very similar, except the Belltech's look slightly more refined.
Here's some links:
http://www.silveradoss.com/forums/in...howtopic=22409
http://www.silveradoss.com/forums/in...opic=14852&hl=
http://www.silveradoss.com/forums/in...opic=19199&hl=
Here's some links:
The fitment issues are directed at the 04 & up SS, VHO, & Vortech Maxx trucks.
It actually shouldn't effect the other 1500 series trucks.
Yes, I did do a lot of research at www.silveradoss.com as well on the lowering kits.
Jim
Jim
Well, I just added one of those little metal coil spacers/locks from Autozone. It stopped the rubbing and the chevy lean seems to be gone in the front. It looks good and turns like normal, so I really don't have any more complaints. Thanks for all your advice guys. I may try what Eye-P said when I drop it another inch (after smaller tires).
Jim
Jim
Here's some links:
Here's some links:
The mcgaughys kit I got was great. The machining was precise, the powder coated rear components were flawless. The packaging was excellent. As far as how rough the casting was......it wasn't perfectly smooth but then again it is a CAST piece and you will never see it behind the rotor anyway.
And to comment on the lower hole in the spindle. There is just as much 'meat' on the mcgaughys as the factory spindle, so I would think it would be just as strong. I have yet to hear of anyone breaking a mcgaughys spindle on the lower ball joint.
As was mentioned......the front suspension setup differs greatly between the vho/ss/tahoe's than the 1500 pickups. I have yet to hear of anyone with a mcgaughys setup on a conventional coil spring front end that was not satisfied. Just some input from a VERY SATISFIED mcgaughys customer!!!
Originally Posted by Colby 04
Please explain, I'm here to learn
My 02 pickup uses a rack/pinion steering system while my torsion bar setup on the tahoe uses the old setup with a pitman arm, inner/outer tie rod ends, etc. Basically the same setup GM has been using for years. Nothing wrong with the setup on torsion bar front ends, it is just different than the coil spring front ends. I think the torsion bar setup actually rides smoother, but the rack/pinion setup yields better steering response and overall fell of the road.
Hope this helps answer your questions about the differences.
Originally Posted by 99Silver6.0
Uh. Calling you on that one. Im running 285/50's with a 2/4. To all the naysayers... They are perfectly fine.
