Invest in 14 bolt or 10 bolt
Old Jan 4, 2016 | 11:38 AM
4xRCSS's Avatar
Registered User
Default Invest in 14 bolt or 10 bolt
I posted before asking if a 2012 14 bolt 6 lug rear axle is a direct swap into my 1999 Silverado 1500. After looking around I haven't found any within a few hundred miles that aren't $1k+ in price. So my question is, would it be worth spending the money and building the 10 bolt with a locker and axles I already have or go and buy the 14 bolt? Just not quite sure what route to go. I don't think ill every be over 800 or so hp in the truck and I plan on doing 4wd launches at the track, so keep that in mind. Thanks for the help
Old Jan 4, 2016 | 11:40 AM
RS/SS 4.8's Avatar
10 Second Truck Club
Plenty of guys on here pushing power through a 10 bolt. Atomic (nevermind hes 14 bolt) and 4x4 and Foose04 is another and he was 2wd.
Old Jan 4, 2016 | 12:24 PM
George C....'s Avatar
Formerly ScreamingL
My 2002 has a 14 bolt
My 2010 has a 14 bolt
Both have girdles
Both have trutracs
By means if you can find one..run one
If not build the 10 bolt
Old Jan 4, 2016 | 01:31 PM
Atomic's Avatar
I have a gauge for that
I have a 14b in mine, and also 4wd.
4wd technically makes it easier on the rear since the power is now being split between the front and the rear. You would probably be fine with the 10b with a decent limited slip. The 14b is a beefier part, but also more expensive and heavier.
Old Jan 4, 2016 | 01:37 PM
dirt track racer 81's Avatar
I hit my 10 bolt with a 350 shot behind my 370 a lot.. Had a stock open carrier with a mini spool and stock carrier.. Never had an issue..
Old Jan 4, 2016 | 02:18 PM
axisT6's Avatar
Funny thing is the 8 lug 14SF axles are cheaper than the 6 lug version and can be converted to run 6 lug very easily while having the benefit of the larger 8 lug brakes. Also comes out MUUUUUCH cheaper compared to buying the 6 lugger.
Old Jan 4, 2016 | 04:49 PM
Formerly ScreamingL
and its a huge power robber
Old Jan 4, 2016 | 05:14 PM
GMCtrk's Avatar
10 bolt is a ticking time bomb.
Old Jan 4, 2016 | 05:29 PM
Formerly ScreamingL
lil sis did go 9.0 with a 10bolt as well going 199.99 mph in standing mile
Old Jan 4, 2016 | 09:51 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Talking
SHHHH!!! Don't give away all the secrets...
