installing tranny cooler, feed/return?
Old Apr 26, 2006 | 09:19 PM
Default installing tranny cooler, feed/return?
ok so im installing a 22000 GVW thinline permacool tranny cooler in series with radiator, the stainless hoses and on the passenger side, 2 of them one high and one low, the directions say to disconnect the return line and install the cooler before that one so i did the which ones hotter test and couldnt really feel a difference, on the 5.3l stock radiator, which stainless hose is the transmission feed line and return line? top or bottom?
Old Apr 26, 2006 | 09:25 PM
twobit's Avatar
I believe bottom is feed and top is return.
Old Apr 26, 2006 | 09:48 PM
thats weird because i would think the hot fluid cam in the top and gravity would pull it down to return in the bottom but i really have no idea so i dont doubt it, thanks twobit, i plan on getting on this install pretty soon, hopefully the hose they gave me will be enough.
Old Apr 26, 2006 | 11:00 PM
The bottom is the feed and top is the return. The engineers did it this way because a counter-flow heat exchanger is more efficient than a parallel-flow heat exchanger.
Old Apr 27, 2006 | 09:39 PM
cbrich, thanks a bunch, ill be getting on this install this weekend, the fuddle will be here on tuesday!!!
Old Apr 27, 2006 | 09:50 PM
TouchOfEvil04's Avatar
It is definately top=return line.I did mine a few months back takes about 30 minutes.Really easy instal.
Old Apr 27, 2006 | 10:44 PM
did you package come with enough hose to go form radiator to cooler in front right behind the grill and back to the stock return line or did you have to buy more?
Old Apr 27, 2006 | 11:20 PM
I had enough hose for mine.I think it was down to like an inch but it was enough.
Old Apr 28, 2006 | 12:14 AM
I did a write-up on a tranny cooler and engine cooler, you will have to run a search on it.
Old Apr 29, 2006 | 01:01 AM
thanks for all the info, with a thinkine tranny cooler does anyone know if i need an extra quart of tranny oil to fill up the extra volume that the cooler adds? if so, what fluid do i need?
