Installed front QA1 coil over kit on my truck
#21
So now I'm curious, what did your truck scale at? Because I'm running a 10" at 800#'s (I know I weigh more in an extended cab but from what I've seen most reg cab guys use 800#er's too)
It looks like you are on the strip the most, but how's the ride?
#24
I will have to ask my suspension guy about the travel it has but if I remember correctly, he said it was a very nice kit and had plenty of travel.
#25
I almost considered going to a 3.1" travel shock and 8" coil but since I've got distance between mounts I figured more travel wouldn't hurt. Seems longer coil can get away with lower spring rate too.
Keep in mind I'm running an aluminum block so that's a little lighter than your usual LS. Yes my truck is setup for the strip but it rides very smooth on the road.
...then I've got a front diff and CV axles thrown up there too..
#27
#28
Your truck also looks way lower than I ever plan to go with 4wd.
Yeah alu. block is like 80lb lighter.
