Installed front QA1 coil over kit on my truck
Old 07-11-2013, 10:58 PM
  #21
TheBeeblebrox's Avatar
Originally Posted by RoadKill03
Thanks. My front springs are 10" and they are 550#'s rate.
So now I'm curious, what did your truck scale at? Because I'm running a 10" at 800#'s (I know I weigh more in an extended cab but from what I've seen most reg cab guys use 800#er's too)
It looks like you are on the strip the most, but how's the ride?
Old 07-12-2013, 05:24 AM
  #22
texasglock23's Avatar
Same, DBRods said 800 for rc and ec, and 850 for cc.
How much travel do you have? It seems like mine only has a couple inches. Still haven't gotten to drive it.
Old 07-12-2013, 05:26 AM
  #23
Mine are 8", I'm wondering why he said to go 8" when you guys seem to be running 10"
Old 07-12-2013, 07:05 AM
  #24
RoadKill03's Avatar
Keep in mind I'm running an aluminum block so that's a little lighter than your usual LS. Yes my truck is setup for the strip but it rides very smooth on the road.
I will have to ask my suspension guy about the travel it has but if I remember correctly, he said it was a very nice kit and had plenty of travel.
Old 07-12-2013, 04:43 PM
  #25
ShredSled's Avatar
Your truck also looks way lower than I ever plan to go with 4wd.
I almost considered going to a 3.1" travel shock and 8" coil but since I've got distance between mounts I figured more travel wouldn't hurt. Seems longer coil can get away with lower spring rate too.
Yeah alu. block is like 80lb lighter.
...then I've got a front diff and CV axles thrown up there too..
Old 07-12-2013, 06:23 PM
  #26
jmgak47's Avatar
Looks sharp man! Would really like to see more pics of the suspension setup also.
Old 07-13-2013, 03:51 AM
  #27
RoadKill03's Avatar
As soon as I pick up my truck from the chassis shop I will take pictures of the suspension and post them up.
Old 07-13-2013, 06:47 AM
  #28
funny thing is, it IS lower than I was planning too!
Old 07-13-2013, 09:07 AM
  #29
Is your suspension guy selling a rear kit?
Old 07-13-2013, 10:05 AM
  #30
RoadKill03's Avatar
I can ask him. I'm sure he can but welding will be required.
Quick Reply: Installed front QA1 coil over kit on my truck
