If you ever pulled out a 4l60e get in here!
Old Jul 11, 2010 | 09:25 PM
  #21
KDavis04ss's Avatar
i would take the T-Case out first. Then drop the trans. We did mine on the ground and didnt have a problem
Old Jul 11, 2010 | 09:29 PM
  #22
KDavis04ss's Avatar
Originally Posted by charcold-bowtie
deep 15mm, 3 foot of extension, a wobble joint with electrical tape on it, and sit indian style at the output shaft. Then its easy lol...
couldn't put it better myself.
Old Jul 11, 2010 | 09:53 PM
  #23
Bluchevypick's Avatar
WOW is all i can say. I pulled my trans out today due to the pump breaking and i had it out and undone from the t-case in maybe an hour. I pull the torsion bar crossmember completely out and drop the trans and t-case down together.
Old Jul 11, 2010 | 09:59 PM
  #24
blue4.8's Avatar
ive had my truck jacked up and tranny sitting on the ground before in an hour by myself but mine is also a 2wd
Old Jul 12, 2010 | 02:23 AM
  #25
99LsSilverado's Avatar
To take the t-case off is fairly easy. It is just 6 or 8 15mm nuts and pops right off while taking your time. I have done it this way several times. That way you dont mess with the alignment after undoing the torsion key placement and have to spend more to realign it. And the t-case only weighs about 75 lbs or there abouts. Then again i rather take that off then have to change the starter in a semi-truck where you can really only use one hand to put it up and in the hole (and they weigh about 65lbs).
Old Jul 12, 2010 | 05:06 PM
  #26
06Sierra2's Avatar
my final thoughts, do yourself a huge favor and grab 3 arp bolts for the TC bolts
do you have a good link for this where i can order them? im getting ready to do a swap and want to be completely prepared, thanks
Old Jul 13, 2010 | 01:00 PM
  #27
nonnieselman's Avatar
http://www.summitracing.com/parts/ARP-230-7304/
I always just put a bolt back in above and below the dowel pins.. So 4 all together. The other 5 you can put in your parts bucket
Old Jul 13, 2010 | 01:27 PM
  #28
06Sierra2's Avatar
thanks. i just ordered them
Old Jul 13, 2010 | 04:46 PM
  #29
fastnblu's Avatar
Originally Posted by joeyc125
Just jack the trans up till it touches the floorpan and get at all three top bolts from atop the motor with a ratcheting 15mm wrench, ...I have done several trucks this way and it sure beats contorting yourself underneath with a bunch of extensions wobbling all over.
I need to remember to try that as an option on my next job, & hopefully not ever again on my '04.
Originally Posted by white1
In my Z-71, by myself it would take about 2 1/2 hours. If youre by yourself its easiest if you pull the transfer case first. I have a modified ratchet I use for that (cut off) As far as the top bolts, Ive done it with a 15mm gear wrench, and with the extensions. Personally I find the gear wrench method is easier if it isnt too tight. If it is, I like to drop the cross member so the tailhousing (transfer case in your situation) is a little lower and angles the bolts down so theyre easier to get to. ...
Oh and you should be able to get 2.5-3qts of fluid in the converter over a couple of days, or at least one in a few hours
white1 had a great tip, among his other good ideas, I hi-lighted that.
I don't have a transfer case, so I'll skip that.
Spray / soak your bolts in advance. Hope that u don't issues removing exh. like I did. Or some had issues w/. T40 torx on top of that brkt. NSS can be a headache too.
Pick up fluid & flush your lines.
Drain your fluid in pan early on. Take all the bolts out except 2. Pivot pan 1 way to drain it out, pivot the other way. That minimizes the mess. Take it off, pour out excess in pan, pop it on.
As charcold-bowtie said a deep 15mm, 3' ext., wobble joint w/. electrical tape, & sitting at the output shaft are your friends.
Get a 90° pick, spin those lil clips at trans fitting, pull out lines w/. a pan under em. Get new clips before u start too.
I was told better than 3 clicks is to verify distance betw. tq. conv. & flexplate.
Maybe cause my stall had some fluid in or cause I poured in all on 1 day, I couldn't get more than 1 QT in conv. (I've heard a cup (or 8oz.) , but also heard a QT. Somethin in there is best.
Figure out how your gonna mount cooler since IDK if u have a factory 1 or not. Those brkts. guys are using are sweet & hook up to TruCool 40K w/. little drama.
I did a thread w/. pics & tips, as did budhayes3. His has t-case info, incl. that lil clip upgrade.
https://www.performancetrucks.net/fo...d.php?t=462976
https://www.performancetrucks.net/fo...ake+that+Billy
Also a bit of info in here too.
https://www.performancetrucks.net/fo...d.php?t=460955
Old Jul 13, 2010 | 05:37 PM
  #30
ang3l's Avatar
just take a bunch of pics so it would be easier for us in the future
