Ideal Highway Temps for 4L60E
Old Nov 1, 2016 | 07:52 PM
mikevanky's Avatar
Default Ideal Highway Temps for 4L60E
I am seeing around 190* on the highway around 75 mph.
Is this normal or high?
It also drop about 20* in stop and go traffic.
I am reading the factory temp sensor on the valve body.
Also I have a decently sized plate and fin style cooler routed before the radiator heat exchanger.
Im thinking about upgrading to a larger cooler if response is that 190* is high.
Old Nov 1, 2016 | 08:18 PM
2002_Z28_Six_Speed's Avatar
Install on return line after radiator cooler or bypass radiator cooler.
Old Nov 1, 2016 | 09:34 PM
FFDP's Avatar
If you want to get technical, that temp is pretty much perfect for fluid life. Anywhere from 170-200 degree's is the ideal temp for transmission fluid on a "life" standpoint.
A larger cooler that doesn't use the radiator should drop those temps 20+ all over atleast and should still get the fluid plenty warm to allow it to do it job well.
Old Nov 2, 2016 | 07:19 AM
About20ninj45's Avatar
If I'm in heavy traffic, mine is around 175-190 in stop and go. On the freeway, my temps is about 130 cruising at 75
Old Nov 2, 2016 | 10:24 AM
someotherguy's Avatar
This ^^^ pretty much all sources report you aren't in danger until you start approaching 220° F or so.
Richard
Old Nov 2, 2016 | 10:30 AM
TXsilverado's Avatar
as long as i'm below 200*, i'm happy.
Old Nov 2, 2016 | 12:53 PM
Atomic's Avatar
I have a gauge for that
It sounds like the converter isn't locking if you are that hot on the highway.
Old Nov 3, 2016 | 07:52 AM
Choda's Avatar
I would be thinking if i was 190 on the highway. here in buffalo it only gets into the 90s a couple times a summer and the roads are fairly flat. 190 seems high to me for no trailer, no load, reg temp outside.
I like to see mine in the around 160.
Old Nov 3, 2016 | 08:33 AM
CammedZ71's Avatar
I run a Stage 2 Performabuilt 4L60E with a trans cooler from a 6.0L Powerstroke. I usually cruise on the highway around 120. Stop and go traffic, I'm usually around 150 - 160. I've almost never seen more than 170 on a really hot day.
Old Nov 3, 2016 | 11:34 AM
tgui's Avatar
Does atf not lubricate as well when cold?
